lower engine mounting bolt removal
Re: lower engine mounting bolt removal
It is the mounting bolt that runs through the lower front section of the engine and then through the frame mounts that hang below the front part of the lower rails. Need to get the images attached soon.
1975 GW - MotoNudohttp://www.ngwclub.com/forum/viewtopic.php?f=16&t=55367
1975 GW - TBD
1975 GW - TBD
okay, then not the one in the picture, but the looooooooooong bolt. I would PB blast it and then a couple of days latter drive it out with a hammer
that's it. I promise to get some pics up soon.
1975 GW - TBD
1975 GW - TBD
Be careful how you remove it. Work at it fairly gently. Lot's of PB Blaster and some heat. Some fairly light tapping. The last thing you want to do is hit it real hard and break the engine case part where the bolt goes through.
will do. Plan on giving it a little effort and then drill and tap for a new bolt.
1975 GW - TBD
1975 GW - TBD
Lads wrote:will do. Plan on giving it a little effort and then drill and tap for a new bolt.
Not sure what you are drilling and tapping. The stock bolt is a through bolt. It is not threaded in to the case or the frame. Just goes through and has a nut on the other end.
Thanks, got the impression it had some threads into the block. Sounds a little less challenging than I thought.
1975 GW - TBD
1975 GW - TBD
yes, the innards just sliiiiiiide through
But, since it sounds like someone used allthread, and many did to install crash bars, so do be careful. I have one in here now that is also stuck, same deal. Allthread from mounting the crash bar. Not sure if I want to chance removing it. As long as the engine never has to come out it isn't a deal breaker. But it would be nice to have the correct part there.
All thread is the worst to use, it holds water in the threads and locks itself in real good. I could not find the correct bolt a couple of years ago, I use metric all thread, but stainless steel. Still gave her a real good slathering with anti seize.
Oh, and I had to use a torch to heat it up enough to get the first one out
I was checking google and found a site with looooooong bolts, as long as I buy 100
rcmatt007 wrote:I was checking google and found a site with looooooong bolts, as long as I buy 100
Christmas is almost here. You could probably find at least a few people that could use one.
- DeltaBlues
Hi as I said in a earlier post, pull this out by tightening the nut onto a spacer, done this several times as they always seize themselves solid in the lovely British weather, apply some heat at the same time if you can, not too much, and if it stuck just do it over a few days the action of doing the nut up tight will keep working, this method has never failed me. Just be aware that if you go a bit heavy handed you do run the risk of shearing the end off, its never happened but it could, also put 2 nuts together, that way the load is spread onto more threads
GL 1100 Std 81'
GL 1100 Aspencade 82' (one day it will rise again)
CB 900 SuperSport 82'
GS 750 77'
VFR 400Z 86' Ex Japanese Training School Bike
GS 750 77'
DeltaBlues wrote:Hi as I said in a earlier post, pull this out by tightening the nut onto a spacer, done this several times as they always seize themselves solid in the lovely British weather, apply some heat at the same time if you can, not too much, and if it stuck just do it over a few days the action of doing the nut up tight will keep working, this method has never failed me. Just be aware that if you go a bit heavy handed you do run the risk of shearing the end off, its never happened but it could, also put 2 nuts together, that way the load is spread onto more threads
Earlier he said he had only about 1/4" of thread to work with. Not much room for a spacer and still be able to catch enough thread.
Seems like a heavy hand already tried that.
