Headlight dimming with turn signals
When turn signal is activated the Headlight (both low and high beam) is slightly dimming momentarily at same rate.
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
76 GL1000 LTD
Austin, Texas
Re: Headlight dimming with turn signals
Bout 95% of the time this would indicate a ground issue. Probably a decent sized green wire inside the headlight bucket. Check to make sure that has a good clean connection and that it reads very low resistance to the neg terminal on the battery.
It would be interesting to know what the system voltage is doing at this point. Assume the bike is stopped and idling? Not a lot of alternator output at idle.
How old is your battery ? Might be worth taking it out and having it tested at your local parts store, most have that ability.
Also, while you are looking at the battery, replace the main dog bone fuse with a modern inline fuse if you haven't already done this.
Is this happening while idling with the brakes on or when you are driving along?
As already mentioned, the alternator doesn't have enough output to keep up with demand at idle and the brake light alone draws almost 2 amps, as does each turn signal.
Also, do you have a higher power than stock headlight or accessory running lights or any other extra electrical loads?
Just going to LED bulbs for the instrumentation, the turn signals & the brake lights free’s up some electrical power in the marginal electrical system in the early GL’s. I went to LED’s to help when I use my Warm & Safe electric jacket liner which works better, still not as good as the high output system in my FJR but good enough. As a side note you need to include include an led compatible blinker, there’s a number of threads here concerning all this if you do a search.
