Having issues trying to rebuild "83" 1100 rear air shocks
quadrunner
My Album: http://www.ngwclub.com/gallery3/index.php/
Post by quadrunner »
I'm in the process of rebuilding my rear shocks including replacing the oil seal and using progressive springs.
I've taken out the oil seal and the other components. I've made the jig to compress the springs that I've found on this site. The problem I'm having is when trying to compress the springs, the top part of the shock mount isn't seperating from the chrome cover.
One thought I had is to mount another bracket above the top of shock and secure it to the 3/8 rods and then tie rap through the shock bolt hole and then try and compress the springs again, but before I do this I wanted to reach out to you guys and see if you can offer any advise.
Regards,
Quadrunner
1983 GL1100
82aspy
Re: Having issues trying to rebuild "83" 1100 rear air shock
Post by 82aspy »
quadrunner
I see where it un screws in the pictures, the problem I'm having is when compressing the spring the top shock mount isn't seperating or staying in the up posistion, it's moving down along with the chrome cover.
1983 GL1100
82aspy
Post by 82aspy »
this is how I popped the top after compressing the shock about 2 inches.
http://www.goldwingfacts.com/forums/att ... small-.jpg
this is what you should get
the original internal rubber bumpers can dissolve into a gooie mush and n/a new from honda
quadrunner
Thanks, I will give it a try later when I get home from work.
1983 GL1100
quadrunner
Thanks for the link, great pictures.
I compressed the springs a little further per your advise & wo la it worked!
I think that when I put in the new springs in , I'm going to use 1/2 threaded rod as opposed to 3/8, as the 3/8 bent some under the pressure.
1983 GL1100
