Will the later style Comstar wheels fit on an 1976 wing in place of the spoked wheels.
If not,does anyone know a source to get a set of new spokes for the older wheels without spending a fortune?
Thanks
1976 WINGWHEEL SWAP
- choppadude
1976 WINGWHEEL SWAP
choppadude
- roncar
Re: 1976 WINGWHEEL SWAP
Yes they will and no I don'tchoppadude wrote:Will the later style Comstar wheels fit on an 1976 wing in place of the spoked wheels.
Thanks
- choppadude
second question
Are all the spacers and such the same between the spoke wheels and the Comstars?
choppadude
- roncar
Re: second question
The only mod i had to do was shim the front brake caliper mounts. The distance between the brake rotors is slightly different.choppadude wrote:Are all the spacers and such the same between the spoke wheels and the Comstars?
Oh, and the speedometer pickup on the wheel is on the left instead of right, so that needs replaced as well.
- choppadude
ElPiloto
Yes; we can manufacture stainless steel spoke kits for the GL1000. The
estimated cost is as follow:
40, 8/10gauge stainless steel spokes w/nipples are $106.40 each front set.
40, 7/8gauge stainless steel spokes w/nipples are $109.60 each rear set.
If you have any further questions, please feel free to call Mon-Sat,
8:30-4:45, (626) 969-4655.
http://www.buchananspokes.com/
- cyclepsycho
- hmratbam
Buchanan wheels will send you a set of stainless Stock spokes for like $63 if I remember correctly. You can spoke a 16 in rear up using CB750 spokes according to Buchanan.
Ron
Ron
My Album
84 Standard ongoing project
My Album
