Shortening the Carb air intake.
- commitedskater15
Not a build thread or a how-to. But i have looked endlessly and cannot find any information or threads on how one might go about putting the airfilter almost directly ontop of the carb intake as opposed to having the filter about a 1/2' above the carbs. Reason I'm asking is so that I can make room for a "real" gas tank to take the place of the false tank.
Thanks, Art.
Thanks, Art.
82 gl1100 Aspencade
Re: Shortening the Carb air intake.
"real " gas tank????? I thought the fuel tank on the goldwing was "real". I mean, it holds fuel, and provides a delivery system to the carbs. Does it get more real then that?? If the fuel tank that is stock on the goldwing is not "real" then it stands to reason the "air filter" isn't real. Which makes me think maybe the carb system isn't "real". So I guess the answer is to convert the whole thing to a single carb design which sits lower.
- commitedskater15
Please excuse my use of the word real.
Thanks, Art.
Thanks, Art.
82 gl1100 Aspencade
- RB
Cut off the rectangle bottom piece and re-weld the bottom of it to the box so you have the trough for the rubber seal and bolt holes??
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Some have gone to a custom flat style filter. Can't seem to come up with any links right now but I have seen it here. It would require fabricating/adapting the lower intake box flange to a flat filter system.
- mrtwowheel
Just thinking that any change to the intake on CV carbs can cause a drastic change in the vacuum that these types of carbs need to work properly. Just changing the size of the filter area would change vacuum flow. I'm just leery of changing anything about the fuel and air, even the one carb setups.
Scott
Scott
'86 1200 Interstate, alternator conversion, pinstriped by Charlie Buzzard
'75 GL1000, Blue Green, fermenting
Many more, mostly Hondas
Newbie, my ass
Newbie, my ass
- NCScooter
- My Album: http://ngwclub.com/gallery3/index.php/w ... ter?page=1
mrtwowheel wrote:Just thinking that any change to the intake on CV carbs can cause a drastic change in the vacuum that these types of carbs need to work properly. Just changing the size of the filter area would change vacuum flow. I'm just leery of changing anything about the fuel and air, even the one carb setups.
Scott
Having read thru Mike Nixon's explanation of CV carbs(> http://www.motorcycleproject.com/text/h ... ork_v3.swf <), I'm not sure that the filter is going to have that much influence. I'd love to have him or Randakk comment on this. Or any of you other gurus. Thanks.
I need to remember to keep my expectations tiny so I don't end up so whiny.
1976 CB400f
1977 GL1000-The Breeze
I'm so special, my short bus only has two wheels!
1976 CB400f
I ran a small round open filter on mine for awhile. I think it is about 6" in diameter and 2" tall. It is for a car. It did make a difference in how the bike ran. Not drastic, but it does run better with the stock air box.
Found a couple pics of my filter.
- SANY0204.jpg (239.47 KiB) Viewed 579 times
- SANY0203.jpg (253.45 KiB) Viewed 579 times
With you on that Robin, I noticed better performance with the stock air box.. I would think you could do the welding trick though.
- gregforesi
It would seem to me that there are two design criteria to consider: The flow through the filter element and the size of the stock snorkel opening. Changing either could have an effect on the stock CV' s and lead to what SunnBobb and Robin have noticed regarding performance with a modified intake.
Any intake mods that provide the same vacuum signal (or curve since it changes with rpm) just ahead of the carbs should allow the same performance as the stock airbox.
Some coil mods have required the snout of the airbox to be shortened. I would suspect that losing the bellmouth of the snorkel would have at least a small effect on what goes on. It's been noted here many times that these are fussy about intake mods but tolerant about exhaust changes. A low airbox is certainly doable with a bit of foresight and thought.
2006 GL1800 (Brutus Maximus)
I have done that mod. I cut mine back quite a bit mostly to make it easier to get the air box out. That mod I have noticed made no difference. On a few different bikes.gregforesi wrote:snip..............
- jdvorchak
Modifying the air intake and putting a gravity fed fuel system on it? At least it will look cool as everyone passes you.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
You have to think Honda had a reason for building that air box the way they did
- John Schmidt
FWIW, I adapted a "real" gas tank from a Valkyrie on to my '84 Std. and use the entire OEM intake system; filter housing & filter, carbs...the whole 9 yards. That gives me a tad over 5 gals. in the tank and lots of room under the seat, plus I think it looks kinda neat. I have the tank hinged at the back end so if I need to get to fuses or filter, I simply unbolt the front mounting bolt and tip it up. I made a platform for the regulator and fuse box that bolted to the original hole the front of the OEM tank inserted into. Fuses are mounted on top and the regulator underneath. It's all wide open under there so should get plenty of air flowing over the regulator to keep it cool. I agree re. Honda's engineering on intake systems. On the Valkyrie Tech Board over the years there have been numerous attempts to "modify" the OEM airbox, all to no or little avail/improvement. Many have cut down areas, cut off portions, drilled holes, the complete gamut and most have returned to buying an OEM replacement off EvilBay to replace their "modified" unit.
Re. the tank, it's off the bike at the moment, got it for $00.00 and needs some real love before using it but can't argue with the price. With a manual petcock it flows good and it appears I won't need a fuel pump since I've already run the engine at high RPM on gravity feed only. Gravity feed worked to feed six cylinders, so it appears to also work to feed only four. Time and miles will tell the story.
All CV carbs are affected by the air flow. Doesn't matter if it Honda, Kawasaki, Suzuki, whatever. I get guys with Kawasaki's that have CV carbs and want individual pod filters on them. It can be done with a jet kit. These come with usually new needles, different jets of course, and a drill bit sometimes. They don't make a kit for a GL though.
- 17 Replies
- 926 Views
Last post by Sidecar Bob
- 8 Replies
- 2630 Views
Last post by 82aspy
- 3 Replies
- 485 Views
Last post by leggman
- 4 Replies
- 495 Views
Last post by CYBORG
