GL1000 Rear Wheel Removal HELP!!!
JonnyFritz
Post by JonnyFritz »
I currently purchased a pretty incredible GL1000. It was a show bike in the 80's and sat for most of the early 2000's. I discovered "mud" in the tank and purchased a new/used tank, but when trying to install the thing I have hit the biggest road block of my life. I spent over 6 hours today trying to remove the rear wheel. I first took the axle out, then the caliper bolt then I worked on it but nothing. I realized the shocks had been upgraded so I took off the bottom shock bolt. Still nothing. I then took off the bleeder bolt (the rear brake cylinder is trashed). This made some progress but not enough to make much a difference so the only thing I could figure was to remove (forgive me Lord Goldwing) the disc while it was still on the wheel. This freed the cylinder from the disc but the wheel still wouldn't budge. Then I gave up. Please help, what would you do?
http://www.myspace.com/thecorndawg
http://www.flickr.com/photos/thecorndawg
RebelRouser
Webmaster (Retired)
Webmaster (Retired)
Post by RebelRouser »
Remove The Rear Brake Mount At The Rear Axle, Slide It Out, Then The Wheel Shim, Then Slide The Wheel To The Left And Out Of The Bike.... You'll Also Need To Remove The Swing Arm To Replace The Fuel Tank...
farmertompetey
Post by farmertompetey »
You sure about removing the swingarm? I just removed tanks from two '77s, and removed rear wheel and otherwise followed Clymer manual, and was able to wrestle them out. At no point did a swingarm leave a frame.
Think I removed the lower bolts on the shocks...
1977 GL1000 (current resurrection project)
(when I'm not digging in the yard...)
Missourimike
Tank Removal
Post by Missourimike »
I just removed and replaced the tank on my '75 yesterday. Needing a new rear tire also, as the one on it was new...made in 1991!
Back to the tire removal...sounds like you have a 16" rear wheel? On mine, I have to pull the rear caliper bleeder valve off to get clearance and everyone needs to remove the caliper and line to the master cylinder when pulling out the tank. No need to pull the swingarm, but of course you have to take the driveline apart at the 3 bolts to the differential and roll it out with the wheel. I don't have to disconnect the shocks...(stock setup) not even for the tank removal.
As for steps on removing the tank....that's a whole 'nother page of notes and tips. Not that hard after you've done it a few times and have a soft 2# mallet handy, knowing where to hit it and at what angle! :twisted: Hope this helps. Take your time and use Patience! I've found that walking away before I got totally :evil: saves time and money in the long run. Calm down and go back later with clear head! It's all fun.
I almost forgot....I cleaned the inside of my tanks with a rust remover called Evapo-Rust, made by Harris Chemicals. Really good stuff, non-toxic, no acid, bio-degradeable (flushable) and it only affects the rust, not the GoodMetal. Cleans good as a wire brush, for me! Check it out.
And Check the Wheel Bearings before re-installing your tire assembly! If you ever have to buy new ones...check the "feel" at the parts counter. I've found too many Chinese bearings without grease and rough as a cobb. I only accept bearings from USA, Japan,Germany or Sweden. Accept no substitutes for good bearings.
'76 Yello Café to be
'83 CX650C Needs Work
'83 CX650C #2 Daily Rider
'79 Yamaha XS750
snowfan
My Album: http://www.ngwclub.com/gallery/v/wingmans/album230/
Post by snowfan »
John
From one who knows...
"pretty incredible"??? :-D
Is that the best you can do to describe it? :lol:
"Calling upon all my years of experience, I froze at the controls"
Sir Stirling Moss
"If you don't know why a dog sticks it's head out of a car window ask a biker"
Unknown
2005 Harley Davidson Road King Classic.
1976 Red Honda GL1000 GoldWing
Visit my album: [url]http://www.ngwclub.com/gallery/v/wingmans/album230/[/url]
randakk
Early 'Wing Guru
Early 'Wing Guru
Re: GL1000 Rear Wheel Removal HELP!!!
Post by randakk »
JonnyFritz wrote:I currently purchased a pretty incredible GL1000. It was a show bike in the 80's and sat for most of the early 2000's. I discovered "mud" in the tank and purchased a new/used tank, but when trying to install the thing I have hit the biggest road block of my life. I spent over 6 hours today trying to remove the rear wheel. I first took the axle out, then the caliper bolt then I worked on it but nothing. I realized the shocks had been upgraded so I took off the bottom shock bolt. Still nothing. I then took off the bleeder bolt (the rear brake cylinder is trashed). This made some progress but not enough to make much a difference so the only thing I could figure was to remove (forgive me Lord Goldwing) the disc while it was still on the wheel. This freed the cylinder from the disc but the wheel still wouldn't budge. Then I gave up. Please help, what would you do?
Jonny:
Normally here's the drill on gas tank removal:
If your tank is rusty, bite the bullet and remove for cleaning and re-furb. This is a bear of a job...very time consuming. Consult your manual for complete details. Generally you will have to remove the following from the bike:
Seat
Rear Shocks
Rear Wheel
Rear Fender
Rear Inner Fender
Rear Master Cylinder (no need to disturb hydraulics)
Final Drive Unit
You will also have to remove the 4 bolts which secure the top shelter (false tank). This is because the rear of the top shelter has to be raised slightly to allow the tank filler neck to slide to the rear. It helps to remove the battery box altogether, but this is not absolutely necessary.
Some manuals erroneously indicate that the swingarm and muffler have to be removed on a GL1000...this is not correct!
But in your case....all bets are off :) Here's Jonny's bike:
I've responded to your email with some suggestions. Good luck!
Randall Washington (Randakk)
Retired Founder - www.randakks.com/
Curator - www.facebook.com/groups/CarburetorAppreciationSociety
david bergstresser sr
rear wheel
Post by david bergstresser sr »
jonny
i .also have a 75, those posts pretty much decribe how i got my wheel off. your ride lokks like a bike that i bid on ebaay couple months ago .simply gorgeous. i dont know wheree u r in philly, but im from near allentown,pa. peteybug has some good instructions for electroloyis cleaning of the tank, which u can do on the bike,if you cant find them ill fax or send a copy to u. whiskerfish, used something called red kote, available at radiator shops to recoat your cleaned tank, says he has excellent results. pm anytime, im home 24/7 almost if u need help or email bergysexp@aol.com
BERGY
you didn't mention if you have a stock 17" rear or a 16". as someone mentioned above, with the 16" you have to lossen the rotor to get things loose
tomward
Post by tomward »
Would somone address the supporting the swingarm to prevent bending it?
What about using a wood block to put inward pressure on the swingarm to get it out?
No wonder the PO left the rear "tire" on and I use the term loosely.Its rubber,its round and its on but is it a tire?
Hoping to get this '83 GL1100 Aspencade up and running as a reliable unit before my son gets back from Afghanistan this time next year.Thanks in advance for your help.
JonnyFritz
I don't know about the wheel. I'm not sure how big it is. I didn't even know it was a white wall tire until I took the bags off and climbed way down under the thing. And Yes I got it on Ebay. It's awesome no doubt but quite a nightmare as far as fixing stuff goes.
I got another tank off Ebay that the guy allegedly "had cleaned". It still has some rusty speckles in it and when I sloshed around some gas it came out with some rusty particles. Not much but it certainly could use another cleaning/coating. What would you recommend for this?
Doug Hasert
Post by Doug Hasert »
On my GL110 I sometimes removed the final drive after doing everything else then the wheel comes out easy without having to lift the bike, 1 piece fender. Also deflate the tire makes it easier if you don't remove the fonal drive. Good luck. Doug
'82 Goldwing/Watsonian Monaco sidecar
JonnyFritz
John
-Sorry, I've been trying to post pictures but they say I need to make 5 posts first. Words don't do very much good on this beast. As soon as I reach my quota and get the word, I'll post some photos. There are pictures online at flickr(dot com)/photos/thecorndawg they're on the right under "1975 Goldwing"
WOW! that is a lot of lights!
looks like you will need to remove a LOT of tupperware before you can do anything.... do you have a mc lift?
Image[/img]
roncar
Post by roncar »
rcmatt007 wrote:WOW! that is a lot of lights!
Image[/img]
Basically got to get from that to this to get the tank out. I thought I had a lot to remove. :shock: :shock: :shock:
starket
Post by starket »
I am wondering if you bought stock in a Chrome Polish and light bulb company when you bought that bike. :-D
Steve Tarket
1975 GL1000 Restoration
1976 GL1000 LTD
1976 GL1000 - Jigsaw +
