starter selinoid replacement---calling wiriing gurus!!!
timma11
Post by timma11 »
will this work? it is for a replacement starter selinoid that i picked up at napa. i will get the part number and post it later. the letters correspond with each other on the two images. i grabbed the bottom image from apost by wiskerfish. thank you!
tim
"studies have found that people with schizophrenia are about twice as likely to smoke pot as those who are unaffected"
mrbswing
Re: starter selinoid replacement---calling wiriing gurus!!!
Post by mrbswing »
timma11 wrote:will this work? it is for a replacement starter selinoid that i picked up at napa. i will get the part number and post it later. the letters correspond with each other on the two images. i grabbed the bottom image from apost by wiskerfish. thank you!
tim
Tim instead of screwing around why don't you buy the one that belongs on there? I do have them you know.till then 8)
Mr Bill
(2)77 wings,two 83 wings 76 CB550 bobber,80 wing,CX500 turbo,700 Nighthawk,2 750 Yamaha triples,80 XS1100 yammy,CB360,600 yammy,CB750 s/s,and a few more? and my main bike(a beautiful 79 XS1100 Yamaha 19,000 miles) and it is very fast! Got another bike a 84 1200 Yamaha I think its a 1200? and more coming. Till then :8)
"DON'T TELL ME I AM WRONG UNLESS YOU ARE RIGHT"
roncar
Post by roncar »
WILL it work? More than likely. I have seen automotive solenoids wired in and they worked fine. My biggest concern is the small amount of space to work in and the very close proximity of the frame. Shorting one of the terminals to the frame is definitely NOT a good thing. That said, I might consider this as an emergency road trip repair to get me home. But would get a proper one and replace ASAP. Probably one with the built in blade fuse if I didn't have a spare at home. If you go this route, use WF's diagram to wire it not the top one. (Ditto mrbswing, just more verbose :lol: )
mooseheadm5
Post by mooseheadm5 »
Do not put hte fuse where they say or else you will have a fused starter. Just hook one large terminal to the battery, one to the starter and the fuse should be connected between the battery and the rest of the bike (AA, not B in the Napa diagram) using one terminal of the solenoid as a junction instead of between the battery and the solenoid. Other than that, it should be fine.
-P
[b][color=blue][url=http://www.ladyada.net/learn/multimeter/]Learn to use a Multimeter, Click here![/url][/color][/b]
timma11
Post by timma11 »
i realize this isnt the best way to do it, but i work in a building behind napa. it is so conveinent. and i am getting sick of my bike not going. i want it done now and am to impatient to order parts. after i get it going, i will look up frenchy or mr bill. i am so frustrated that all my hard work is just sitting in the driveway. the damn thing is registered and insured already and i cant use it. I WANT TO RIDE!
You need a ride and then a dozen or so beers. :lol: :lol: :lol: :lol:
Do it right. Shortcuts suck! 3 years from now when it craps out and you look at a stock schematic nothing will make sense. Get the stock one and do it the right way and you will be much happier in the long run. I know waiting sucks but when your machine purrs and will run down $30,000 hogs life is good.
roncar
Post by roncar »
timma11 wrote:....... I WANT TO RIDE!
This is where MBS comes in...... :lol: :lol: :lol:
Multiple Bike Syndrome
one dressed
one naked
one in parts
one for parts
etc.......
mooseheadm5
I would not be too concerned about this particular change to the wiring. A solenoid is just a really high current relay, and as such there really is only so may ways to hook it up. Two fat wires to the two big terminals and one from the start button and the other to ground through the clutch/neutral circuit. I'd do it if it were cheap enough, and I am a stickler for things like this, but I would include a diagram stuck to the inside of the left side cover if I were worried about it.
-P
timma11
Post by timma11 »
one dressed
one naked
one in parts
one for parts
etc.......
remember when i almost caught mbs? there is a thread about a certain '76 limited i wanted and how uncomfortable my couch is and being promised "no more promises" from the misses.
anyway, it worked!
it will look a lot better when it is all buttoned up. i put it on and it fired right up. there is some issues with the starter switch though. only works in certain spots. that will be investigated later. thanks for all your input. i now can ride!
timma11
mooseheadm5
Yay! That looks, uhhh, functional. At least it works!
-P
RIP: 1950-2011
Post by Cookie »
Now how did I miss this whole thread? It was all over before I caught on.
Thrills, chills, excitement and I'm in the back yard with Scotchbrite and Tide.
mrbswing
Post by mrbswing »
Cookie wrote:Now how did I miss this whole thread? It was all over before I caught on.
see what happens when you are playing the home body/ gardener.lol till then 8)
Mr Bill
RIP: 1950-2011
Post by Cookie »
You don't think I was housecleaning do you? I was just cleaning my fuel tank before painting.
I took my wife to dinner at a new restaurant to get points back. (after painting.)
purplegoldwing
Post by purplegoldwing »
A piece of 2 or 2.25" radiator hose off a car cut about 3" long or so and slipped over the solenoid and held on with a hose clamp or a couple of wire ties could offer some short circuit protection. It that is too thick I am thinking that a piece cut out of an old bicycle inner tube wrapped around it might offer enough protection.
Bill
Naked custom 78 GL1000
1984 GL1200 Aspencade
2003 BMW K1200RS (for sale)
1985 GL1200 project: conversion to semi-standard
Pictures at:
http://www.flickr.com/photos/hubbell
Follow your heart, not the crowd!
Old Fogey
Post by Old Fogey »
purplegoldwing wrote:A piece of 2 or 2.25" radiator hose off a car cut about 3" long or so and slipped over the solenoid and held on with a hose clamp or a couple of wire ties could offer some short circuit protection. It that is too thick I am thinking that a piece cut out of an old bicycle inner tube wrapped around it might offer enough protection.
Good thinking!
Tim, you really need to do something to insulate it all from the frame.
We'ed all hate to see oyur machine go up in smoke after all the work you've put in :(
