Wheel Swap
- champab
- Lead Member
Wheel Swap
I have a 77 Gl1000 and would like to put Comstar wheels on it in place of spokes. Is this a direct bolt in or is it complicated?
wings rule
rear is no problem.... front... lotsa problems.... brake calipers, fork lowers, speedo sender and rotors all all different
often lester mags are on ebay, but the fronts go for high $$$
- roncar
Re: Wheel Swap
The front wheel, brake rotors, and speedometer pickup need replaced. Brake calipers need shimmed to make up the difference in rotor offset.champab wrote:I have a 77 Gl1000 and would like to put Comstar wheels on it in place of spokes. Is this a direct bolt in or is it complicated?
See thread Here
And Here
