It is currently Sat May 25, 2013 4:09 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3, 4  Next
Author Message
 Post subject: Stator plug replacment done right
Post Number:#1  PostPosted: Sat Mar 22, 2008 6:17 pm
Offline
Brass Member
Brass Member
I replaced the stator plug on my wing and documented the process on the following page.
http://www.oregonmotorcycleparts.com/GWstatorplug.html
I will be adding more info on cleaning, repairing and replacing connections as I get to it.
Tony
_________________
Old enough to know better but to crazy to care.
Top
 Profile
 Post subject:
Post Number:#2  PostPosted: Sat Mar 22, 2008 7:41 pm
Offline
Webmaster
Webmaster
nice job.
_________________
"I prefer the abstract concept of incoherence in the face of great feeling to beautiful, full sentences that convey little emotion." DDL
1978/9 Arthur Fulmer Dressed Road bike
Top
 Profile
 Post subject:
Post Number:#3  PostPosted: Sat Mar 22, 2008 7:51 pm
Offline
Yep,
That should pass the concours inspection but mine won't.
_________________
Top
 Profile
 Post subject:
Post Number:#4  PostPosted: Sat Mar 22, 2008 8:50 pm
Offline
Brass Member
Brass Member
Cookie wrote:
Yep,
Maybe the plug will but not the rest of the bike. It's a 1975 with a GL1100 engine of unknown year in it.
Tony
_________________
Top
 Profile
 Post subject:
Post Number:#5  PostPosted: Sat Mar 22, 2008 10:32 pm
Offline
Mine looks like an old bus mechanic worked on it, that isn't corrosion, it's patina.
_________________
Top
 Profile
 Post subject:
Post Number:#6  PostPosted: Sun Mar 23, 2008 11:14 am
Offline
Brass Member
Brass Member
I bought a 79 Yamaha 1100 that was like that. The wiring harness was so butchered I was only able to use it for parts but that was back before I was able to get new connectors.
Tony
_________________
Top
 Profile
 Post subject:
Post Number:#7  PostPosted: Sun Mar 23, 2008 1:45 pm
Offline
The one on the yellow bike mostly cleaned up with a few replacement sections. On my red bike there is not much hope for the stock harness, which is fine since I intend to modify it.
_________________
Top
 Profile
 Post subject:
Post Number:#8  PostPosted: Sun Mar 23, 2008 4:01 pm
Offline
Brass Member
Brass Member
Let me know it you have any problems with it. I make repair harness sections on custom order. Like with the plug cleaning and repair, I've been meaning to do a page on this for a long time...
BTW, I replaced the rectifier plug and added it to the bottom of the page with the stator plug. Later on I will do a page showing the repair of a few different plugs. I think I'm done documenting the replacement of plugs for a while.
Tony
_________________
Top
 Profile
 Post subject:
Post Number:#9  PostPosted: Sun Mar 23, 2008 5:36 pm
Offline
I guess you did not know the "old bus mechanic" Cookie was referring to is none other than Cookie himself :-D .
_________________
-P
Learn to use a Multimeter, Click here!
Top
 Profile
 Post subject:
Post Number:#10  PostPosted: Sun Mar 23, 2008 8:10 pm
Offline
Yep, they are a bit simpler to wire than a Greyhound or train.
I like wiring a lot better than most of the other tasks. I've got to pull the oil pan off my Chang soon which should involve oil falling in my face. I'm not looking forward to that at all but better to cure leaks before the riding season.
I probably should pull one jug too as I have a small leak there also.
_________________
Top
 Profile
 Post subject:
Post Number:#11  PostPosted: Sun Mar 23, 2008 11:52 pm
Offline
Brass Member
Brass Member
Cookie, are you the guy that contacted me about making parts for a Chang Jiang? It's an interesting beast but I never did get the info from the dealer that was supposed to help with the project.
I imagine that wiring a truck or bus wouldn't be any easier that on a bike. Sure the wires are larger but you don't have to stand on your head to get to the weird places on a bike. One reason I never liked working on cars and trucks is all the crawling around underneath always turned me off.
Tony
_________________
Top
 Profile
 Post subject:
Post Number:#12  PostPosted: Mon Mar 24, 2008 3:45 am
Offline
It might have been possible Tony that I contacted you about Chang parts but I don't recall it just now. What was the part? There was somebody in the Pacific NW that offered to make me fork bushings last year but I got a set in Denver.
It was actually a Chang guy named Dan who sent me to this site when I said that I was thinking of making an early Goldwing sidecar tug.
_________________
Top
 Profile
 Post subject:
Post Number:#13  PostPosted: Mon Mar 24, 2008 10:57 am
Offline
Brass Member
Brass Member
That wouldn't have been me. I only make charging system parts right now but I'm working on branching out into electronic ignition modules.
Tony
_________________
Top
 Profile
 Post subject:
Post Number:#14  PostPosted: Mon Mar 24, 2008 8:06 pm
Offline
Why do you think there is so much for stator problems on these? Is it just the corrosion on the connectors or too small a unit for the load?
_________________
Top
 Profile
 Post subject:
Post Number:#15  PostPosted: Mon Mar 24, 2008 9:14 pm
Offline
Brass Member
Brass Member
It's hard to say. I do know that a stator has more internal heat when the connector is corroded but I don't know of a 4 cylinder wing that hasn't corroded the connectors...
Other bikes will knock out a stator from time to time with good connections so it could just be that we are seeing the normal failure rate.
Tony
_________________
Top
 Profile
Who is online
Search for:
Jump to:
Go Mobile
