It is currently Tue Jun 18, 2013 3:25 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 14 posts ]
Author Message
 Post subject: Valve Clearance Adjustment, How-To
Post Number:#1  PostPosted: Wed Aug 08, 2007 4:17 am
Offline
Engine must be Stone-Cold . . . that's overnight-cold.
1. Remove the valve covers by loosening the four 10-mm bolts evenly and in a diagonal pattern. This helps to avoid distorting the covers.
Orient yourself to the piston numbers. The first time on an unfamiliar engine it's a good practice to make numbered masking tape labels and stick them near the set of valves for each cylinder.
2. Remove the spark plugs. Remove the timing mark cover and rotor bolt cover.
3. Place your 12-mm offset-box-end wrench on the rotor bolt. Rotate the engine clockwise until the intake valve on #1 cylinder opens and closes. Pull up only! You do not want to loosen that rotor bolt. #1 Intake is the upper valve on the right front cylinder.
4. Continue rotating until the flywheel's T-1 mark is aligned with the index marks on the case. #1 is now at TDC (top dead center).
5. Check the clearance on the following valves by running the correct size feeler gauge between the valve stem head and the adjusting screw.
    #1 Intake - - .004" (.10 mm) - - - right front, top
    #1 Exhaust - .005" (.13 mm) - - right front, bottom
    #3 Exhaust - .005" (.13 mm) - - right rear, bottom
    #4 Intake - - .004" (.10 mm) - - - left rear, top
6. If the gap on a valve is incorrect, loosen the nut with a 10-mm box wrench and screw the adjuster in or out with your screwdriver. Use a light touch here and don't push in on the screwdriver. Turn the screw in until the feeler gauge won't move, then back off slowly until it just starts to move. You want just a little resistance to movement here. When it's correct, the next size larger gauge will not easily slide in and the next one smaller will be sloppy-loose.
7. When the adjustment is correct, tighten the nut while holding the adjustment screw in position with the screwdriver.
8. Torque the locknuts to 9-12 lb.ft. (1.2-1.6 kgf m) and re-check the clearance on #1 intake and exhaust, #3 exhaust and #4 intake. Adjust any that are incorrect.
9. Rotate the engine 360 degrees clockwise until the T-1 mark is again lined up the the index marks. #2 piston is now at TDC. Check and adjust the clearance on the following valves as you did in Steps 6 & 7.
    #2 Intake - - .004" (.10 mm) - - - left front, top
    #2 Exhaust - .005" (.13 mm) - - left front, bottom
    #4 Exhaust - .005" (.13 mm) - - left rear, bottom
    #3 Intake - - .004" (.10 mm) - - - right rear, top
10. Torque the locknuts to 9-12 lb.ft. (1.2-1.6 kgf m) and then re-check the clearance on #2 intake and exhaust, #4 exhaust and #3 intake. Adjust any that are incorrect.
11. An additional check should be done at this time as described in Steps 12 -15.
12. Rotate the engine 360 degrees clockwise. #1 intake will open and close. Align T-1 to the index marks. #1 is now at TDC. Check #1's intake and exhaust valve clearance and re-adjust if needed.
13. Rotate the engine 180 degrees and align the T-2 mark. #3 is now at TDC. Check/adjust valve clearance on #3.
14. Rotate the engine 180 degrees and align the T-1 mark. #2 is now at TDC. Check/adjust valve clearance on #2.
15. Rotate the engine 180 degrees and align the T-2 mark. #4 is now at TDC. Check/adjust valve clearance on #4.
16. Inspect, clean/replace gaskets and refit the valve covers. Torque the 10-mm bolts to 6-9 lb.ft. (.8-1.2 kgf m) evenly and in a diagonal pattern.
17. Inspect, clean/replace O-rings and refit the timing mark cover and rotor cover. Do not overtighten!
18. Go for a ride and enjoy the weather.
NOTE: Valve clearance varies on GL1000 and GL1200. Consult your manual for details. Also, on a GL1000 you should follow this with ignition points and timing adjustments.
Here's an alternate and easier method from one of our members.
jdvorchak wrote:
If one valve on a cylinder is moving the other is not. I don't even look at the crankshaft position for setting valves. I turn the crank, by hand, in the direction of normal engine rotation and watch one set of valves. When the first valve starts moving, lets say the exhaust valve, I then adjust the intake valve. Then I spin the crank until the intake just starts moving then adjust the exhaust. Then move to the next cylinder on that side of the bike and repeat. Then move the to the other side of the bike and just watch the valves to start moving again and repeat for that side. With this method it's pretty much a no-brainer and you don't have to keep jumping from side to side and trying to remember, "is that #3 exhaust or #1 intake...what timing mark is lined up on the crank," etc.
Now, a good carb. sync. is probably in order. Click=>> Randakk's Carb Synchronization Procedure.
Click Here to get the printer friendly PDF of Valve Clearance Adjustment, GL1100.
ImageFoxit PDF Reader FREE, small, quick: replaces Adobe Reader (2.6 MB, Windows only)
Intellectual Property Notice:
Feel free to LINK to this material. However, the content published here is the property of Steve "Roady" Mate, and is protected under United States and international copyright laws. The photographs, text and other content may not be copied, reproduced, republished, distributed, stored, or manipulated in any manner without the express written permission of Steve Mate.
Top
 Profile
 Post subject:
Post Number:#2  PostPosted: Wed Aug 08, 2007 7:16 am
Offline
Very nice, thanks for posting the pics. I like the little pointers most....
_________________
82 GL1100 Interstate-Oldewing
77 GL1000 Black and Hacked, Velorex car and a gem set.....
68 CB 350 Wifeys and oh so cool
25 percent stake in 898 project, *beverages consumed.
Sometimes I wrestle with my inner demons..........
Top
 Profile
 Post subject:
Post Number:#3  PostPosted: Wed Aug 08, 2007 7:25 am
Offline
Absolutely brilliant Steve!
Thanks a lot!
We'll move it to 'Octanes corner'
to make it a 'sticky!.
Top
 Profile
 Post subject:
Post Number:#4  PostPosted: Wed Aug 08, 2007 9:28 am
Offline
Webmaster (Retired)
Webmaster (Retired)
Asome Informational.... But What Do You Use If You Can Not Get The Rotor Bolt Cover Off??? What To Do Then??? On The Early Wings You Can Use The Kickstarter To TurnOver The Motor And Do Your Valve Adjustment... Again Aswome Informational 8)
_________________
Top
 Profile YIM
 Post subject:
Post Number:#5  PostPosted: Wed Aug 08, 2007 1:05 pm
Offline
Thanks, guys, I had some fun doing it.
RebelRouser wrote:
.... But What Do You Use If You Can Not Get The Rotor Bolt Cover Off??? What To Do Then??? On The Early Wings You Can Use The Kickstarter To TurnOver The Motor And Do Your Valve Adjustment....
That and the little flywheel cover gave me a headache too. Some dude (I think it was the big guy, Bubba "Muscles" McTorque) down at the local shop really laid into both of mine. The rotor bolt cover (17-mm) required the big breaker bar & extension with a padded pry bar to hold it on. Yep, just like valve adjustment it required 3 hands. For the timing cover I ground the tip of an old prybar into a crescent and clamped the ol' reliable vice-grips onto it.
I guess you could turn the engine by rolling the back wheel...?
_________________
Steve -- IBA #8078 -- Winnie, the '81 Nekkid Bagger build
Image Image Image Image Image Image
Top
 Profile
 Post subject: Thanks Steave [Roady] Valve Adjustment
Post Number:#6  PostPosted: Tue Aug 28, 2007 2:21 pm
Offline
Thanks Steave for posting Valve clearance adjustment.
This will make things a lot easier to understand when it comes to my turn. Once again Thanks Ringo twinky
_________________
Hi all fellow wings Its good to be with you all Ringotwinky from England
Top
 Profile
 Post subject:
Post Number:#7  PostPosted: Thu Feb 14, 2008 11:32 pm
Offline
Thanks, Steve!!! Just did it!
_________________
Doby
1983 Naked GL1100
1995 Customized VS1400
2000 Vulcan Classic
Top
 Profile
 Post subject:
Post Number:#8  PostPosted: Fri Feb 15, 2008 1:33 am
Offline
With those pointers that was really nice. I can appreciate that because I did the one for Changs with a guy from LA called Jeff Pierce, I think he is better at explaining things to novices.
Those pictures should really help folks.
_________________
Top
 Profile
 Post subject:
Post Number:#9  PostPosted: Mon Apr 28, 2008 10:18 am
Offline
Lead Member
Lead Member
I think I can do it now!
It sounded nice in the books, but these details are AWESOME!
Thanks again, Phil
_________________
Thanks,
Phil
'78 GL1000, '77CB550F
Clinton, SC
Top
 Profile
 Post subject: # 4 cylinder never gets loss
Post Number:#10  PostPosted: Tue Nov 24, 2009 3:05 pm
Offline
Lead Member
Lead Member
:?: I can never get any play either in the intake or exhaust for # 4 cylinder. Could it be that far off. I have turned the crank around many times but never gets any play. What is up?
_________________
RM Thanks You
New owner 1981 gl1100
Top
 Profile
 Post subject:
Post Number:#11  PostPosted: Tue Nov 24, 2009 3:28 pm
Offline
is this a running engine befor you started? do you see any movement in the valves at all when you turn it over?
_________________
click the banners below:
Top
 Profile
 Post subject:
Post Number:#12  PostPosted: Tue Nov 24, 2009 3:34 pm
Offline
Lead Member
Lead Member
I am in the process of bringing it back to life. Didn't run for about two years and the person passed away. I received it and put a new starter in it and it fired right up. Starts right up and sounds strong. Valves on number 4 go in and out but never get any clearance to adjust. I didn't want to back the screw all the way out but I don't even think that would do it. The rest are fine.
_________________
RM Thanks You
Top
 Profile
 Post subject:
Post Number:#13  PostPosted: Tue Nov 24, 2009 3:40 pm
Offline
if infact backing the screws out does not give you clearence. measure the height of the springs from the head, and compare it to the valves that can be adjusted. if they are taller, eather the engine has the wrong valves in it, or, more then likly, the valves have pounder themselves into the head. i've never seen that, but something is wrong if you can't get a feeler gauge between the top of the valve and the adjusting screw. bring the piston to top dead center on the cyl. that is a problem and see if the rocker arms are loose.
_________________
Top
 Profile
 Post subject:
Post Number:#14  PostPosted: Tue Nov 24, 2009 4:12 pm
Offline
Lead Member
Lead Member
Thanks will try it.
_________________
RM Thanks You
Top
 Profile
Who is online
Search for:
Jump to:
Go Mobile
