viewtopic.php?t=79155#p830592
Idea for fuel injection setup
Thurem
Post by Thurem »
I have been thinking about how to simplify the building of a fuel injection system for the my 1100 wing.
Basically I wanna build a plenum with a single throttle body and the injectors mounted on a single fuel rail inside the plenum, with the injectors pointing into the individual throats of the plenum. Think sealed rectangular box with 4 tubes to connect to the stock intake elbows, with fuel rail and injectors inside and a throttle body on one end.
Off course this would later get connected to a turbo....
I'm pretty sure it would work, but would I be paying a price with drive ability or poor idle quality?
'81 GL1100
fish
Re: Idea for fuel injection setup
Post by fish »
At idle the inside of your sealed box would be high vacuum
At WOT this would change to atmospheric pressure.
remember the difference between BAR & PSI
Timothy Mark Fisher
Catalina Arizona
fish wrote:At idle the inside of your sealed box would be high vacuum
:shock: talk about splitting hairs!!!
1 bar = 14.50377438972831 PSI
fish
Post by fish »
if the fuel pressure regulator is inside the plenum, the fuel pressure would fluctuate up to 2 BAR
Timothy Mark Fisher
Catalina Arizona
Thurem
Post by Thurem »
"if the fuel pressure regulator is inside the plenum, the fuel pressure would fluctuate up to 2 BAR"
Yep, just like any other fuel injected engine. The fuel pressure regulator is usually referenced to engine vacuum/pressure. Basically you want to have the fuel pressure a set amount (i.e. 40 PSI) over what the pressure is at the tip of the fuel injector. That way the ECU does not have to compensate for varying pressure.
So, back to my question, will the drive ability be affected by this less than ideal, but simplified setup? I'm thinking that it should be better than a single carb or throttle body injection. But not as nice as a multi point injection where the injectors are aimed straight at a hot intake valve.
Does anyone have experience with a setup like this or something similar?
'81 GL1100
triwing
Brass Member
Brass Member
Post by triwing »
Is installing an injector on each intake manifold, (drill &tap) an option? Does anyone use a flex hose of any kind to supply the injectors with fuel at the needed pressure? Probably not, but you never know. I think it would work if so. Anyone know how Honda did theirs? One of the sixes had injectors on each intake if my memory serves me. triwing
82aspy
Post by 82aspy »
82aspy
Post by 82aspy »
Thurem wrote:I have been thinking about how to simplify the building of a fuel injection system for the my 1100 wing.
simplest tbi i've seen is over at classic using 90-4 suzuki swift parts with megasquirt, (5k miles)
someone else modded a stock ql12 fi plenum & injectors onto a 1100,
info on this site regarding gsxr fi parts modded
Casper
Post by Casper »
The intake layout on a Rotax is very much like a GoldWing's engine. It would not take much, in the way of mods, to use that set up on a GoldWing.
Thurem
Post by Thurem »
"simplest tbi i've seen is over at classic using 90-4 suzuki swift parts with megasquirt, (5k miles)"
Do you have a link for this, please? Don't know what classic you are referring to.
'81 GL1100
I recall one here, but like many it never got going.
wow, that is a clean setup
82aspy
Post by 82aspy »
Thurem wrote:"simplest tbi i've seen is over at classic using 90-4 suzuki swift parts with megasquirt, (5k miles)"
classic goldwing
fish
Post by fish »
WOW!!
Boyoboy does that look EXPENSIVE!
Timothy Mark Fisher
Catalina Arizona
Thurem
Post by Thurem »
'81 GL1100
