It is currently Sat May 18, 2013 8:46 pm
Post new topic Reply to topic  [ 14 posts ]
Author Message
 Post subject: remove rear break sticking
Post Number:#1  PostPosted: Tue Feb 10, 2009 8:47 pm
Offline
This was done on a stripped frame for clarity. Tools needed. Drill, drillbit 13/64, TAP 1/4-28, oil, rapidtap fluid, 1/4 grease fitting (zert) and sandpaper. First you have to remove rear break pedal from bike. You have to remove a small cotterkey and a large washer to remove pedal(no pic sorry) You can remove pedal from master cylinder(cotterpin & and small pin) or you can leave it as is and pull cylinder and all. Its up to you. When you get it off you will notice shaft has a groove.
this is area where you will want grease fitting. put a mark on peddle where groove is.
I have found that putting grease fitting on the bottom of the peddle makes it easier to get at. Now set up your 13/64 drill bit in your drill and drill hole in pedal tube make sure to use oil so bit stays lubed. Next take your 1/4-28 tap and tap out.
Now you have threads to screw in fitting. Take emerypaper or sand paper clean out hole and make smooth. Do the same to shaft. Take grease fitting and washer and screw in.
The reason I used 2 washers was because fitting sticks in to far so pedal will not go back on without it. Or you can put pedal on then use just the fitting. Now put back on bike and put break unit back together. Now sock some grease to it and you should have no more problem with sticky pedal. You will notice I drilled hole on top of this pedal :oops: had to go get a 90degree fitting.
_________________
Top
 Profile
 Post subject:
Post Number:#2  PostPosted: Tue Feb 10, 2009 8:53 pm
Offline
Webmaster
Webmaster
Good stuff!!!
On another subject I had a second fuel pump crap out on me today. All your parts are laid out on the bench for in the morning :-D :-D
_________________
"I prefer the abstract concept of incoherence in the face of great feeling to beautiful, full sentences that convey little emotion." DDL
1978/9 Arthur Fulmer Dressed Road bike
Top
 Profile
 Post subject:
Post Number:#3  PostPosted: Tue Feb 10, 2009 8:56 pm
Offline
Good luck :lol: I am having great success with the new spring. Running low on craped out pumps to rebuild.
_________________
Top
 Profile
 Post subject:
Post Number:#4  PostPosted: Tue Feb 10, 2009 10:19 pm
Offline
Awesome! Way faster than pulling it off, packing it and re-attaching it.
-Deek
_________________
Top
 Profile
 Post subject:
Post Number:#5  PostPosted: Wed Feb 11, 2009 10:19 am
Offline
Damn......... there's that Rapid Tap again !!!! :-D
Dave.
_________________
If it ain't broke, don't fix it.
'80-'81 GL 1100 Hybrid Vetter Interstate 90K km
1989 GL1500 58K mls
Previous bikes
1973 Suzuki GT 500
1975 BMW R60/6
1982 Suzuki GS 550
1980 GL1100 (frame went to current bike, rest parted out)
1983 GL1100 Interstate
Top
 Profile
 Post subject:
Post Number:#6  PostPosted: Fri Feb 13, 2009 12:22 am
Offline
Great. This is linked on ShopTalk now.
Thanks, peteybug!
_________________
Steve -- IBA #8078 -- Winnie, the '81 Nekkid Bagger build
Image Image Image Image Image Image
Top
 Profile
 Post subject:
Post Number:#7  PostPosted: Fri Aug 28, 2009 11:00 am
Offline
NOTE:
Anyone doing this modification should probably consider one thing, before drilling...
Look at where your large shaft spring seats.
Mark your hole location outside of that area, while still allowing grease to penetrate the shaft cutout area.
I learned this lesson, the hard way.
I had to fill my first hole with marine epoxy & drill in a new location.
Live...Make mistakes...Learn...CYA.
:-D
_________________
KB
1976 GL1000 Nudewing
Top
 Profile
 Post subject:
Post Number:#8  PostPosted: Wed Sep 02, 2009 11:25 am
Offline
Thanks for sharing this modification :idea:
Grtzz, Miky.
_________________
There are two types of motorcyclists, those who fell and others who are yet to fall.
Apologize for my Google english!
1978 Honda GL1000 K2
1997 BMW R1100RT
Top
 Profile
 Post subject: Re: remove rear break sticking
Post Number:#9  PostPosted: Wed Feb 03, 2010 2:48 pm
Offline
I'm having trouble getting rear :x :x brake pedal off the pin. It was set up when I bought the bike. I've slowly been working it back and forth - with a hammer, sprayed WD-40. Today I even heated it w/ propane torch and got out the pickle fork. It is still there! Am I missing something?
_________________
Rick
Top
 Profile
Post Number:#10  PostPosted: Wed Feb 03, 2010 6:10 pm
Offline
Webmaster
Webmaster
There is a cotter Key and a large washer that have to be removed before it will slide off the shaft
_________________
Top
 Profile
Post Number:#11  PostPosted: Thu Feb 04, 2010 8:23 pm
Offline
Whiskerfish has it right, only the cotter key, a washer and a pile of rust keep the pedal in place. If you wish to make this modification by Peteybug, watch out where you drill the hole, leave space for the spring!
Grtzz, M.
_________________
1997 BMW R1100RT
Top
 Profile
Post Number:#12  PostPosted: Thu Feb 04, 2010 11:01 pm
Offline
Thanks for the replies. I had already removed washer, cotter pin, and spring. I guess it is just "set up". My next step might be a torch!! I'm getting the frame powder coated Sat.
_________________
Rick
Top
 Profile
Post Number:#13  PostPosted: Fri Feb 05, 2010 9:58 am
Offline
Webmaster
Webmaster
Soak it with penetrate and work it. Eventually it should slide off.
_________________
Top
 Profile
Post Number:#14  PostPosted: Fri Feb 05, 2010 10:05 pm
Offline
It gave in to the up & down wrench - hammer!!
Thanks.
_________________
Rick
Top
 Profile
Who is online
Search for:
Jump to:
Go Mobile
