It is currently Tue May 21, 2013 8:14 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Author Message
 Post subject:
Post Number:#16  PostPosted: Thu Aug 24, 2006 8:50 am
Offline
I then took a peice of 1 1/2 inch pvc pipe to help press the seal down into the shock... you push a little further than it needs to be... put in the retainer washerand the retaining ring. when you apply air pressure, the seal will snug up o the retaining washer and ring, and that is it.
my electrcal tape hole closure did leak just a small amount from the pressure of pushing in the seal
_________________
78 wing we have had since.... well.... 78, been in nearly every state, 76 Ltd "cookies bike" up and running, still needs some work, 79 project, back in pieces while I move, '86 1200 (Beth's) with motrvation sidecar, 05 HD Road king and 08 HD Heritage softail (Beth's). I guess you can say we have MBS
viewtopic.php?f=30&t=27685
viewtopic.php?f=30&t=35846
Image Image Image
Top
 Profile
 Post subject:
Post Number:#17  PostPosted: Thu Aug 24, 2006 8:53 am
Offline
from here, it was reapplying the outer rubber boot (no picture) and then putting everything back on the bike, and best yet, there has been no leakage overnight! :-D
like most projects, the time was in getting everything off the bike to begin the work, all in all, the time doing the seal was really only about 15 minutes... so if you had a shop do it, the bill should be their minimal amount, provided you have taken the shock off for them.
_________________
Image Image Image
Top
 Profile
 Post subject: Nice
Post Number:#18  PostPosted: Thu Aug 24, 2006 10:34 am
Offline
Nice work Rodger, thanks for the informative post.
Got a couple of old pairs of shocks for the 1100 that I may fix up and sell now that I've found some Progressives. :-? .
_________________
"I'd rather Ride than Shine" -
'80 GL1100 Interstate, 'R2B' (RAT TO BE)
And now Team 898
Top
 Profile
 Post subject:
Post Number:#19  PostPosted: Thu Aug 24, 2006 6:09 pm
Offline
i know someone who might need some replaced, repaired, frixed ... front fork seals made a big difference ...still feeling a hard thump when hitting small bumps in the road... road seams and such ... haven't check em out ....they look intimidating ... give it a shot this weekend.
Hugs
Q
_________________
O, for a horse with WINGS ~Shakespeare
____*____*____*____*____*____*____
Most things make me say, hmmmmm
80 GL1100 Image
I didn't say it was your fault, I said I was going to blame you!
Top
 Profile
 Post subject:
Post Number:#20  PostPosted: Tue Mar 18, 2008 8:44 am
Offline
mbrizfam590
here is the rebuild info
_________________
Image Image Image
Top
 Profile
 Post subject:
Post Number:#21  PostPosted: Thu Aug 13, 2009 3:37 pm
Offline
Rusty Probie
Rusty Probie
wish i had found this earlier .i just spent £80 on replacement airless shocks
_________________
why do the three musketeers always use swords
Top
 Profile
 Post subject:
Post Number:#22  PostPosted: Thu Aug 13, 2009 4:13 pm
Offline
Somewhat off-topic, but in a similar vein...
Does anyone know if it's possible to shorten Progressive air shocks?
_________________
KB
1976 GL1000 Nudewing
Top
 Profile
 Post subject:
Post Number:#23  PostPosted: Thu Aug 13, 2009 5:27 pm
Offline
I have heard of guys cutting the spring shorter. But you loose travel that way. And I don't imagine that the cut end is properly "flat".
I also have seen spring clamps for shortening car coil suspensions.
_________________
TomE
Big Red, a '75 Wing
Black Beauty, a '99 Valkyrie
Top
 Profile
Who is online
Search for:
Jump to:
cron
Go Mobile
