Valve Grinding
Victour
My Album: http://good-times.webshots.com/album/570131144RgmY
Valve Grinding
Post by Victour »
I used to work in a automotive machine shop 100 years ago I milled heads polished cranks and did valves and seats ok it was in 72 .
I heard one time that you can buy the stones all ready cut to the right angles..I really don't know where I want to take it in town and would rather do them myself.. the intakes Seats are pitted a little because the 2nd PO let rain get into the intake.. all he had to do was put the cover back on and saved me a big head ache.. the valves themselves are fine just need lapped . the seats can be replaced if need be.. maybe I could go to a little larger VW valve.lol
1978 Gl1000 LTD
http://good-times.webshots.com/album/570131144RgmYiK
TomE
My Album: http://www.ngwclub.com/gallery/v/wingmans/TomE/
Post by TomE »
I hear that these valves are hardened and they should not be ground, only lapped. Don't know about the seats, but it would make sense if they were hardened also.
Someone will come along soon with a definitive answer!
TomE
Big Red, a '75 Wing
Black Beauty, a '99 Valkyrie
RIP: 1950-2011
Post by Cookie »
Kind of makes you wonder if they are only surface hardened or if Honda just wanted to sell you new valves. There have always been a fair number of rebuilt component failures and a lot of manufacturers avoid rebuilding now, the only way to tell wound be to grind one and check the harness, perhaps with a Rockwell machine.
I've also heard not to grind them several times now.
starket wrote:Grinding the valves should not be done on a Wing. You can lap them but not grind them.
_________________
Steve Tarket
1975 GL1000 x 2, 1 is naked and the other is a full dresser, I got MBS
85 Spree
Polishing Sucks
Yes I am a computer geek. It is part of my job.
The way I understand it is that the valves and seats have a material coating (stellite?? is the word that comes to mind??) that precludes the grinding operation. I believe I have read or been told that this was a preventative measure against burn't valves. Seems to work as you do not hear about burnt valves very often and we have folks screwing with the tunning all the time.
puffy75
Early 'Wing Guru
Early 'Wing Guru
My Album: http://www.ngwclub.com/gallery3/index.p ... ns/puffy75
Post by puffy75 »
The valves have a Stellite coating on them for hardening this is true. It is so the valves can be lighter. That is important for the high RPMs
The seats can be ground has it states in the manual. You need 3 degree angles 63.5, 45 and 37.5. The three angles are used to move the 45 needed for the valve seat to the middle. There are 3 angles for better flow across the seat(where the valve actually sets on the seat).
You can use blueing to tell which way the seat needs to move and then make the correct cut to move it up or down. Lap after cuts, do not lap with seal in place.
Make sure you check for leaks when done. I like to assemble the valve and spray contact cleaner in the port and watch for leaks. This helps you know that it will be good before assembly of head to cases.
May The Fours Be With You.
CB77 1965 First Bike
GL1000 1975 "Puffy" damaged in accident
CB750F2 1978
GL1000 1976 "Puffy Too"
roncar
Post by roncar »
Beat to it again! :lol: Oh well I made the pic already.
Victour
Post by Victour »
that's what I am talking about Roncar... where do I buy the 3 stones to get the angle's I know after one time use they would need to be trued up again to keep the angle..
1978 Gl1000 LTD
deafyet
Post by deafyet »
I was told the stellite was cast into the actual part, and therefore ok to grind...I hope..... :-?
1978 gl 1000, nekkid w/ sidecar, 1965 ca77/Dream 305, 2008 Kawasaki Versys
Victour
Post by Victour »
Sorry Deafyet.. but Stellite can only be sprayed using a torch setup.
1978 Gl1000 LTD
mieze245
Lead Member
Lead Member
Re:
Post by mieze245 »
Victour wrote:that's what I am talking about Roncar... where do I buy the 3 stones to get the angle's I know after one time use they would need to be trued up again to keep the angle..
http://www.newaymfg.com/
1980I
