Dyna S - recommended coils
78wing
Post by 78wing »
I wanted to pass along some information I got from talking with Dynatek. For those using the Dyna S system for GL1000, the recommended coils are the DS10-1 (5.0 ohms).
1978 GL1000 - twin Weber project
78wing
Post by 78wing »
Correction - I was about to order the DC-10-1 coils but noticed that they only have one terminal. I called again and the correct coils should be DC8-1. These coils come with ballast to replace the stock ballast.
Frenchy
Post by Frenchy »
I use, & carry the DC1-1 (3 ohm). The instructions included with the unit, recommends using OEM ballast resistor with points, & no resistor with an electronic ignition.
Frenchy
78wing
Post by 78wing »
There doesn't seem to be a simple answer to this one - Dyna tech support recommend the 5ohm coils but it seems like several forum members have run the 3ohm coils without any problems.
Can anyone comment?
randakk
Early 'Wing Guru
Early 'Wing Guru
Post by randakk »
78wing wrote:There doesn't seem to be a simple answer to this one - Dyna tech support recommend the 5ohm coils but it seems like several forum members have run the 3ohm coils without any problems.
Can anyone comment?
Everything I know about the subject is here:
http://www.randakks.com/TechTips.htm#38
I agree with Frenchy...3 ohm coils are recommended.
I have asked both Accel and Dyna to review their conflicting recommendations regarding whether one should retain, omit or change the ballast when using aftermarket coils with Dyna S.
Part of the discrepanancy may be that Dyna is making some sort of fuzzy distinction between their 3 ohm and 5 ohm coils.
But, the fact is that most suppliers stock the 3 ohm coils.
Randall Washington (Randakk)
Retired Founder - www.randakks.com/
Curator - www.facebook.com/groups/CarburetorAppreciationSociety
78wing
Post by 78wing »
Thanks Frenchy and Randakk for the replies - I will go with your advice over the company's recommendations!
I will be running Dyna S ignition and so will run DC1-1 coils (3 ohm) with no ballast.
Kghost
Post by Kghost »
Hey frenchy whats a set of them coils and a Dyna S set one back these days?
I have a coil going bad.
Theres a race of men who dont fit in
A race that can't stand still
So they break the hearts of kith and kin
and roam the world at will
Dave of Hutto
Post by Dave of Hutto »
Kghost, where did you get that seat and tail peice? I have my brothers 76 he gave me and I can't decide on an Adventure Bike or a Cafe set up.
I am not in a hurry, your just slow!
That yellow 76 in my avitar, I miss daily. Should have kept her.
Kghost
Post by Kghost »
Dave of Hutto wrote:Kghost, where did you get that seat and tail peice? I have my brothers 76 he gave me and I can't decide on an Adventure Bike or a Cafe set up.
I made it dave. Base is an old corbin pan
Frenchy
Post by Frenchy »
Kghost wrote:Hey frenchy whats a set of them coils and a Dyna S set one back these days?
The coils run $145, & the wires run $25 plus S&H: http://www.crescentmoonunlimited.com/ht ... ition.html
Frenchy
