It is currently Wed Jun 19, 2013 8:46 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: Wber 32/36 with Manifold
Post Number:#1  PostPosted: Thu Oct 28, 2010 2:42 pm
Offline
Here is the finished product. As anyone who has been following my progress knows I got this just about spot on. The carb is just a little rich out of the box but it runs great.
Brent
_________________
I can build anything you can afford!
http://community.webshots.com/user/vagrant50
Top
 Profile
 Post subject: Re: Wber 32/36 with Manifold
Post Number:#2  PostPosted: Thu Oct 28, 2010 4:25 pm
Offline
Brent
Oooh! Pretty!
Have you had a chance to try it on your bike yet?
How did it do?
_________________
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
Top
 Profile
Post Number:#3  PostPosted: Thu Oct 28, 2010 4:28 pm
Offline
Well being blind in one eye and not being able to see outa the other, I completely missed the next thread that said you did get it on your bike. :orange
Two Thumbs Up!
_________________
Try Jaywalking!
Top
 Profile
Post Number:#4  PostPosted: Mon Nov 15, 2010 7:40 pm
Offline
Ok Guys here is a little update on the Carb and manifold. I have found that the boots on the right side are a little too long and tend to try end collapse after heavy riding. I guess when they warm up and the RPM's are up they try to flatten out. Simple fix is I made two collars out of the same material as the runners and cut the boots in half and inserted in the middle. Fixed pretty simple. Few hours machining and a few beers and well you know how it goes. And now for the gas Mileage. I am getting over 130 miles on a tank in town. 95% of which is 35 MPH in town. I think that is pretty good. Need a road trip to see what the long distance highway is going to be.
Brent
_________________
Top
 Profile
Post Number:#5  PostPosted: Mon Nov 15, 2010 9:14 pm
Offline
action1 action1 That's great Brent,... that's about what I get with my single barrel Holley!!! Any bogging down when using the 2 barrel transition? Good job, hippie1
_________________
Robert White
Top
 Profile
Post Number:#6  PostPosted: Sun Nov 21, 2010 9:08 pm
Offline
A little when it's cold but not bad. I also ended up going another 20 miles till the tank was dry. So its 150 in town. Man I will have to get the seat redone I won't be able to sit between fillups!
Brent
_________________
Top
 Profile
Post Number:#7  PostPosted: Sun Nov 21, 2010 10:28 pm
Offline
good reporting, thanks!
_________________
Image ---- Bradshaw Bikes offers polishing and upholstering for your Wing!
Top
 Profile
Post Number:#8  PostPosted: Wed Dec 22, 2010 7:09 am
Offline
If I forget and don't turn the fuel spigot back to the on position, I get about half a mile from the gas station before it quits.
_________________
Try Jaywalking!
Top
 Profile
Post Number:#9  PostPosted: Wed Feb 23, 2011 4:46 pm
Offline
I have some updates on the system. Runs great but I have found that the marine grade exhaust hose will not hold up as expected. It will last a while but will develop problems. I took the four original intake manifolds and ground off the section that butted up to each hose and then sounded it down smooth. This allows the hose to slip further down and get a better seal as well as allow some position adjustment and not risk the hose coming off on the road. I also shortened the aluminum runners on the fabricated manifold to allow for longer hose. This aids in fitting the manifold and carb sine things are pretty tight inside the frame. I switched over to inch and half ID fuel hose with metal rings in it so it will not flaten out. It is the same kind of hose that is used on refuil trucks at airports. The hose now has a slightly larger diameter than the runners and does not flatten out which does away with any restrictions. This seems to be a long lasting fix and clears up alot of headaches.
Brent
_________________
Top
 Profile
Post Number:#10  PostPosted: Thu Mar 10, 2011 2:32 am
Offline
Hay Brent, how's the bike performing as to date? How is the color on the plug tips? Reason I asked was I'm finally getting around installing the Holley Weber and I see you have the primary facing to the front of the bike and was wondering if you had any problems with the carb that way,...( I'm also facing mine that way also but I see Randall W. has his backwards on His beast)??? Just wondering if any problems like cornerning or anything to worry about? :crosso hippie1 Thanks, Bob
_________________
Robert White
Top
 Profile
Post Number:#11  PostPosted: Fri Mar 25, 2011 8:52 pm
Offline
Mine is mounted with the primary to the rear and the fuel inlet on the right.
Places the choke connection at the rear and the throttle bellcrank on the left side.
_________________
Try Jaywalking!
Top
 Profile
Post Number:#12  PostPosted: Sat Mar 26, 2011 12:42 am
Offline
Hay Z, I've been procrastinating wither to put the Holley/Weber on because of what happened last time, darn near blew my ear drums out from backfirig and I'd swaer made T-belts jump a couple tooths. I've got mine set up Sec's. in back, I wouldn't think that would hurt,.......... I just have to quit talking about it and " Get Er Done" !!!!!!!! Do you still have that plenum I want :lol: :lol: ,.. Ride safe Bro :crosso Later, hippie1
_________________
Robert White
Top
 Profile
Post Number:#13  PostPosted: Mon Apr 18, 2011 3:03 pm
Offline
The setup is working great. The cable needed lubing recently though. The carb was loading up when running around three thousand rpm's for a while. A quick twist of the throttle and she idled right down. i lubed the cable and seems to be fine.
Brent
_________________
Top
 Profile
Post Number:#14  PostPosted: Thu Apr 21, 2011 1:50 am
Offline
Brent,
Very interesting manifold, I am interested in how you fabricated it.
I would like to make a manifold for a throttle body only with fuel injection with an injector in each port.
I am working on a setup now using a modified LD manifold and putting injector bungs in Honda manifold adapters to put on my bike.
Glad that this is working for you, I am now running a LD manifold with a Pic 30 carb, works good.
_________________
1979 Goldwing
Top
 Profile
Post Number:#15  PostPosted: Fri May 06, 2011 2:11 pm
Offline
I took a board and bolted the original runners on it. The tubing is aluminum. The bowl is from a fire extinguisher turned upside down. I used flat aluminum to seal the top and bottom. The top plate was placed on after I sanded the inside of the runners where they were welded to the extinguisher top. The runners where made by placing them onto the original runners and then hours upon hours of cutting and measuring to get them just right to weld onto the fire extinguisher top. No simple task for sure. the small hole on the fire extinguisher top has a flat plate welded to it just about even with the runners. I used the gasket for the carb to make the top piece for the carb to bolt too. The throttle linkage was made from scratch again with a lot of measuring and cutting. i taped it for the original pull cable to screw right into. I can not stree enough cut a little and remeasure. It's a whole lot easier to cut a little more off than have to put a little back. Put the runners on the extinguisher first before you do anything else and get them exactly how you want them.
Brent
_________________
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Go Mobile
Powered by phpBB® Forum Software © phpBB Group
