Diamond in the Rough: My 75 Goldwing
- BigBrian27
Re: Diamond in the Rough: My 75 Goldwing
Sneak peek at the frame!
- 0128171144.jpg (101.07 KiB) Viewed 282 times
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
nice
- BigBrian27
I'm getting ready to stuff this engine in. i suppose it's better to have the frame as a roller first? Or should I put the frame over the engine while it's stripped?
Putting the frame over the engine is much easier.
- BigBrian27
Thanks. I'll sucker a buddy into giving me a hand.robin1731 wrote:Putting the frame over the engine is much easier.
I could scratch that one up easily. Suggestions here are to wrap frame pieces with rags or pipe insulation to protect it.
- BigBrian27
I was going to use blue painters tape.ericheath wrote:I could scratch that one up easily. Suggestions here are to wrap frame pieces with rags or pipe insulation to protect it.
- BigBrian27
Got a buddy to come over and help me throw the engine in frame.
Put some oil in her and threw the frame over. Shortly noticed an engine oil leak... NOT good.
Pulled the frame back off and tracked it down. Appeared to be coming from the rear cover.
Pulled the rear cover off and saw that I had left a washer on one of the studs which obviously wouldn't let the edges seal.
Removed the washer and ordered a new gasket, man I hate setbacks!
Better now than later
- BigBrian27
My thoughts exactly.ericheath wrote:Better now than later
I had put that washer back on the stud so I would not forget where it goes during re-assembly.
I was mad at myself when I realized what I had done but also relieved that it wasn't something more serious such as a damaged mounting surface.
- BigBrian27
Making progress!
- 0213172003.jpg (114.78 KiB) Viewed 209 times
- 0213172003a.jpg (120.51 KiB) Viewed 209 times
- BigBrian27
Did some rotor drilling last night.
- FB_IMG_1487189136197.jpg (57.57 KiB) Viewed 195 times
- FB_IMG_1487189144125.jpg (57.63 KiB) Viewed 195 times
- BigBrian27
All finished!
- 0216172306_HDR.jpg (108.67 KiB) Viewed 178 times
- Sugs
Looks good, how many bits did you go through?
_______________________
'79 Honda GL1000 Goldwing
- BigBrian27
Ok so I drilled 3 rotors. I used two 3/16" bits and two 9/32" bits and chamfered the holes with a 7/16" bit. So 5!Sugs wrote:Looks good, how many bits did you go through?
- 14 Replies
- 555 Views
Last post by rcmatt007
- 1 Replies
- 202 Views
Last post by Track T 2411
- 9 Replies
- 554 Views
Last post by WalterM817@aol.com
- 27 Replies
- 1458 Views
Last post by lcallison
