click here:
viewtopic.php?t=79374#p833813
My Preservation restoration
davhj
Post by davhj »
I've owned this bike for about 10 years now and only paied $200.00 dollars for it. Three years ago I desided to do what I'll call a "Preservation Restoration". This is what I ended up with.
I'll tell the whole story after I get all my pictures all sorted out and a bit of a story going.
I still have a few minor things to sort out but it runs, sounds good and goes down the road straight.
Dave
It's a 1975
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
1990 Sea Ray 350 Express Cruiser
2000 Harley Davidson Electra Glide Classic
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=46946 (My Preservation Restoration)
davhj
Re: My Preservation restoration
Post by davhj »
This is what it looked like before I started the project.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
Jimbo1
Post by Jimbo1 »
Wait a minute. Did you leave a "0" out of the paid for price? That's a real steal!
davhj
Post by davhj »
No, I didn't leave an "0" out of the price But I've added a few "000's" to the built total.
It's been a fun project, I spent more money that I care to admit but it was well worth it.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
davhj
Post by davhj »
This is as far as i striped it down to, I put the back wheel back on and took it outside and throrouly degreesed and washed it down.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
davhj
Post by davhj »
After a good cleaning I painted just around the battery box area waxed the frame with some color restore wax and started the rebuild process.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
davhj
Post by davhj »
The next thing I did was to adjust the valves, new timing belts, valve cover, and timing belt cover gaskets.
I cleaned up the valve covers, timing belt covers and everything inside the timing belt area.
Next I worked on the wireing harness, I cleaned it up like new, replaced some of the wrapings and cleaned every terminal end with a brass wire brush and the female ones with a tiny brass bottle brush. I replaced the stator plug with the kit from Origon Motorcycle Parts it is a exact replacement.
Don't know how that happened but the picture is up side down.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
She turned out real nice. Yep, the bought-it price is not anywhere near the finished price, is it?
davhj
Post by davhj »
Roady wrote:She turned out real nice. Yep, the bought-it price is not anywhere near the finished price, is it?
No not even close, I'm into it well over three grand. The big ticket items were the original seat, exhaust, headers and of corse the grab rail.
I still have to sort out a few issues, like the 7 volt system for fuel and water temp, and last night I was syncing the carbs and I found out the fan is not comming on I know the fan motor works so it must be the sensors or something.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
davhj
Post by davhj »
Got the raidaitor and all its bits sorted out cleaned up and assembled, put the wireing harness, coils and the raidiator assembly on the bike.
I bought all new cables, new thermostat, gasket kit, adjusted the clutch inside the back cover.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
davhj
Post by davhj »
Dave[/quote]
Well the 7 volt regulator is good, replaced fuel float sender with a good one but still no reading on the fuel gauge. Not sure on the temp gauge yet I have to start it up again and still have to sort out the radiator fan switch.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
First thing on the fan switch is to pull the connector off and jumper across it. If the fan runs then you can move on to checking the switch. It can be rebuilt if you're so inclined.
davhj
Post by davhj »
Roady wrote:First thing on the fan switch is to pull the connector off and jumper across it. If the fan runs then you can move on to checking the switch. It can be rebuilt if you're so inclined.
That is a great tip Roady, I'll try that first before draining the coolant and switching it out. It's a good thing my 77 Wing is a long term project because I've been stealing parts off it to try on the 75.
Thanks,
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
Off topic, but I guess the 75's didn't have a support tube at the midpoint of the upper tube behind the false tank frame??? I'm referring to the tube that is cut a bit to change the rake ala HOTT. My 77's have them as do the other years.
Easter
Post by Easter »
It is a beautiful bike and worth the cost of restoration. Wish I could find one that nice for $200 even if it takes $3000 to bring it back to health.
83 GL in process :IDTS:
