so decided to go with some shorter rear shock/springs (tired of the tiptoe thing) This should gain me an inch
opps... there is a left over space on the mounting bolt
three 5/8 washers (powder coated black to be not noticable) does the trick
as long as I was there a quick bracket to make the sissy bar work made out of 1 inch stock and also powder coated black
Taken my time restoring an LTD
Re: Taken my time restoring an LTD
Let us know how those progressive rear shocks do, as the aged shocks most of us run are not idea and create evil handling on occasion.
took it for a spin today and they aren't as stiff as the ones I took off, so that is a good thing. Also, could touch the ground much easier. turned out my idea for the sissy bar meant I could not get the seat on. the problems was the hole that would tie in with the mounting bolts in the back left the front too far forward. so I ended up lining up the front, and I will have to figure something for the back
Just thought I would add a picture of an addition I made a couple of weeks ago
Like it.
- Zinc Member
switch it over to the conversion ,screw on filter
Brian Mcknight 1979 GL1000,1995 Electraglide
mandu57 wrote:switch it over to the conversion ,screw on filter
- 23 Replies
- 1138 Views
Last post by rcmatt007
- 14 Replies
- 2591 Views
Last post by wingrider
- 3 Replies
- 328 Views
Last post by Norbert R
- 15 Replies
- 1449 Views
Last post by doubleminded
- 16 Replies
- 668 Views
Last post by theburgundian
