Loud mouth '78
Re: Loud mouth '78
Pulled the center stand off this evening and with the help of some muffler repair tape used as a gasket, mounted the muffs directly to the headers. I hammered out the hangers from some 3/16 x 1 flat stock I had on hand. Still need to drill the holes and mount to muffler and passenger peg. Looks clean but is really close to the rear tire, hope there is no conflict.
Re: Loud mouth '78
Got the mufflers mounted but still waiting on the seat. Took it out for a run the other evening before the cold front blew through. Lots of fun to ride. I had just gotten off the 1200 standard that I have been fiddling with and it was a big difference. I like this bike! Unfortunately when I pulled in the garage and shut it down, smoke was drifting out of the front of the shelter. At first I couldn't find a cause but after a more careful exam I realized the fuse box was melting! I haven't had a chance to chase down the cause but i am suspicious that it is overcharging and heating up the main connection to the fuse panel. But the box is probably going to have to be replaced so I am looking at blade type fuses. I need to watch the gauge more carefully to see if it is actually overcharging. I know it was reading around 16 at first but I assumed that it was going to settle down after warming up. Apparently not. OR it could be something else altogether.
Re: Loud mouth '78
I don't think an overcharge condition would manifest itself in the fuse box first. (I could be wrong). Those are "service circuits". They'd see overvoltage, but the slightly higher current shouldn't cause a meltdown. The charging current goes direct from stator to r/r and battery. Sounds like you have something else going on, too. Like a short. Hopefully, a GL guru will weigh in on this.
Re: Loud mouth '78
A short would seem obvious except no fuses blew out so I was looking for something else. Will dig deeper in the next few days. Pretty cold here by South Texas standards, not a good time to be in an unheated garage.
Re: Loud mouth '78
I hesitate to mention it but today was a beautiful day here in South Texas with afternoon temp near 80. But--we will get to suffer a little bit along with the rest of you as the cold front is to hit here sometime tonight with an overnight drop of 60 degrees or so.
Well, this isn't meant as a weather report or "too bad you don't live down here" but I did get out for a 40 mile ride in near perfect conditions. This was the first time this bike has been out of the neighborhood and I was quite pleased with how it did. The seat is quite firm and the rear shocks don't, and I really can't recall if I ever put oil in the front forks after rebuilding them (!!) didn't feel like it. That is something I will have to check into. The volt meter was showing a steady 16 volts the whole time, but fortunately I had a spare regulator and it is now showing a much healthier 14 volts.
I was able to get some photos with the new seat and a couple of other details like the Harley mufflers and the idiot lights mounted in the headlight. Still having a problem with the neutral light, as it stays on all the time. Not sure i am up to pulling the engine a third time just for that.
- 20161217-_DSC0031.jpg (786.19 KiB) Viewed 225 times
- 20161217-_DSC0024.jpg (758.79 KiB) Viewed 225 times
- 20161217-_DSC0025.jpg (818.76 KiB) Viewed 225 times
- 20161217-_DSC0035.jpg (493.57 KiB) Viewed 225 times
- 20161217-_DSC0017.jpg (852.5 KiB) Viewed 225 times
Re: Loud mouth '78
Very slick. Looks like a good sled from over here.
- NCScooter
- My Album: http://ngwclub.com/gallery3/index.php/w ... ter?page=1
Re: Loud mouth '78
Lookin' great. I had a question about those straight (30 degree?) pipes you had on at first, or straight pipes in general. I like the sound but worry that the lack of back pressure will damage my exhaust valves. Tell me in a nice way that I'm out of my mind. I had Sportsters on, they didn't do anything for me, personally.
I need to remember to keep my expectations tiny so I don't end up so whiny.
1976 CB400f
1977 GL1000-The Breeze
I'm so special, my short bus only has two wheels!
1976 CB400f
Re: Loud mouth '78
I really can't say one way or the other about the valves. I agree the Sportster pipes are a bit too quiet but the straight pipes were over the top for me. I have a set on my orange bike that are early Sportster and they are not nearly as restrictive as these.
Re: Loud mouth '78
love the look of your bike, I also have Dyna mufflers and I drilled out the baffle with a step drill 3/4 hole. I love the sound, bad when your on it and when cruising, you can barely hear it.
CB 160
BSA 350 Enduro Star
CB 450 (2)
CX 500
GL1100i
GL 1500
currently
1978 GL 1000
BSA 350 Enduro Star
CB 450 (2)
CX 500
GL1100i
GL 1500
currently
1978 GL 1000
- HOTT
Re: Loud mouth '78
Looks great! Sorry I missed this. Did you solve your Neutral light?
I would have suggested a false or redundant ground.
Re: Loud mouth '78
Thanks Hott, no haven't worked on it much since. But will look into that. It would be nice to get it to work properly. Right now it just serves as an indicator that the key is turned on!
- HOTT
Re: Loud mouth '78
... just serves as an indicator that the key is turned on!
Yeah I gotta few of those too..
- HOTT
Re: Loud mouth '78
Well Hey Hey Hey !!! Congrats on BOTM
Re: Loud mouth '78
Congrats on BOTM!
- flyin900
Re: Loud mouth '78
Congrats on BOTM too. I really like the colour combination and the electric fuel pump is a nice addition.
The neutral switch can be removed without removing the motor if that is what it turns out to be. I did one on an 80 Standard using the FSM procedure of flexing the frame to get some extra room.
Current Bikes:
- 18 Replies
- 997 Views
Last post by duke182
- 266 Views
Last post by Dirty Dave
- 6 Replies
- 195 Views
Last post by hmratbam
- 18 Replies
- 593 Views
Last post by Old Fogey
