Really Naked GL1500
Re: Really Naked GL1500
So how about a winter review of the naked beast? How many tickets did you get?
I would say nude for sure! Like
- IMG_4696.PNG (930.34 KiB) Viewed 783 times
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- Mike-C
Good Evening Folks;
Bob, I like it. One of the fellows at work had a 1500 that was totaled in a low speed accident. I was thinking of buying it but thought the better of it, seeing this one makes me think I should have.
Mike Coleman
'84 Wing-Lite (ex-Aspencade)
'84 un-Terstate
Mike Coleman
'84 un-Terstate
Mike Coleman
North Lancaster, Ontario
Canada
Canada
Nope, I'm a Honda Man through & through.delling3 wrote:KTM fan by chance?
As you can see this was a budget build, re-purposing whatever we could form the pile of crap we took off and from other bits lying around.
Color choice was limited to what colors were available on the bottom shelf at WalMarts the day we went paint shopping. Engine is Hammered Black from a can I found on the shelf in the workshop,
Front fender is from original, rear fender from the pile.
Lights and indicators are LED Running lights from Banggood, about $2 each. BTW, these are VERY Bright and awesome for telling everyone in your path that you are there!!!! I'm thinking of adding one strip under the headlight on my Beemer to make sure those idiots who want to pull out in front of me have NO EXCUSE......You cant help but see me!
Full function Speedo, Rev, gear, oil, headlight, charging, neutral console was about $45 from Banggood.
Rearview camera was about $6, Rear view screen about $15.
I rewired 90% of the harness throwing everything away apart from the ECM and immediate harness. I used the connectorrs from the harness to attach all the re-purposed stuff.
I also removed ALL plumbing under the tank.... Exhaust air bleed pipes, high altitude solenoids and carb tubes, inlet manifold heating plumbing and radiator fans and anything else that didnt deliver fuel or create sparks. The pile of tubes, pipes, solenoids and associated crap after I went through removing was like 'Borg Porn' (Think Star Trek)
The ONLY mod I made after running it for a while was to go up two sizes on the main jets..... That mod took it from fun to ride to a tire burning Beasty as it was way too lean over about 1/4 throttle. No problems with get up and go now!
As it stands it weighs in at about 450 pounds, 300+ of those being the lump in the middle.
Bob Manifold
Older, fuller-figured, bike nut living in rural Connecticut
94 GL1500A Really Naked, Tangerine Dream
81 GL1100 Naked, Carbon Fibre Black Beauty
81 GL1100 based Ice Racing Sidecar
78 BMW R100/7 (Original Owner) My regular ride nowadays
86 CR500 Ice Racer
77 Ex-Works FANTIC 200 Trials Sidecar (Will Hawkes bike)
99 Montessa 305 Trials Sidecar
99 Ex-Works Bultaco Sherpa (Andreu Codina's bike)
79 Bultaco 199A Sherpa
65 Honda CA77 305 Dream
73 Yamaha DT250
81 XR500 (600cc) StarRacer Dirttrack
86 CR500 Ice Racer
73 Yamaha DT250
Dear Mr Moderators
Can you please move this topic to the Underground Customizinig Forum?
BobM
BobM
Bob Manifold
86 CR500 Ice Racer
73 Yamaha DT250
86 CR500 Ice Racer
73 Yamaha DT250
Let me say again, it looks like great fun and I have my eye out for a 1500 cheap. Have seen a couple but looked like they were missing so much of the important running gear as to make them too expensive to work with.
moved
So now I know how to post pictures directly, here are the latest pics
Bob Manifold
86 CR500 Ice Racer
73 Yamaha DT250
86 CR500 Ice Racer
73 Yamaha DT250
She isn't likely to win any beauty contest but she has a unique personality. Lots of fun to hang out with.
- RIP: cookie
Looks .... LOUD ....
- BikeMaine
Is that seat the copy of the Harley Davidson Police bike?
If so, how comfortable is it?
Kevin
1982 GL1100A
1982 GL1100A
- Brass Member
Can you explain or show how its just connected to the ignition box. I received a free wrecked 1995 interstate no reverse. and I am not going to put all the plastic bits back on. I just want to clean up the wiring hanging all over and figure out after how to make the fake tank and fairing. Currently the previous owner removed all the air solenoids except one and the small vent lines on carb are all hooked to each other and not to any lines on bike.
- Mike-C
Folks;
There is nothing like a free motorcycle and free Wing is 10X better !
Mike Coleman
'84 un-Terstate
Mike Coleman
'84 un-Terstate
Mike Coleman
Canada
Canada
- 38 Replies
- 1791 Views
Last post by salukispeed
- 7 Replies
- 2662 Views
Last post by Liam
- 5 Replies
- 313 Views
Last post by jdvorchak
