Just another bobber build
Re: The $1000 bike build!
where did you mount the ignition key? im thinking abouyt moving mine and placed it where you have yours but how did you attach it haha
1980 GL1100I (parts)
1978 GL1000
"I Have No Idea What I Am Doing."
1978 GL1000
deathbypizza wrote:where did you mount the ignition key? im thinking abouyt moving mine and placed it where you have yours but how did you attach it haha
If you go back and look at post #26 there is a clear picture of it.
- Hamp
I put 1/2" bolts through the factory ignition holes and ran a nut up to hold the bolts in place. I put another nut on the very end of the bolts. Then after cleaning off the paint where I wanted to mount it, and temporarily securing the Ignition Tumbler; I welded the end nuts to the frame so you can still remove it if necessary.deathbypizza wrote:where did you mount the ignition key? im thinking abouyt moving mine and placed it where you have yours but how did you attach it haha
"Riding is life" -me
1981 Honda Goldwing bobber "Wang"
& a few other toys
& a few other toys
Rad thanks!
1978 GL1000
1978 GL1000
- Hamp
Something doesn't look right with the new headlight mounts. Maybe they stick out too far... Opinions? I spent $60 on these CNC allum brackets so I am going to have to live with them for a while. I wanted to mount the headlight lower, but the brackets turned out to be 2mm too small
PS. I will probably order stainless braided brake lines because the factory lines are swelling and giving me a very spongey feel on the brake pedal & lever. Does anyone have any suggestions? I would like to keep it under $125
& a few other toys
& a few other toys
- Ric
I like the brackets, not bad at all! But would be better with a side view pic, to see how much they stick out
- Sugs
Yeah, I like my headlights low and tucked in, like a Ducati monster. Even the stock mounts are too far out and too high. I purchased a new set and then drilled new holes until the headlight was where I wanted it.
_______________________
'79 Honda GL1000 Goldwing
IMHO, the headlight is out too far, but if you are using a real bucket behind it, it will make a difference on how it looks.
Looks as though the brackets could be rotated around 160-170 degrees to the inside for a tighter pull back. Might need some spacers on the headlight. Also, pulling the visor off will give it a different look.
Bike is really looking nice.
- Hamp
+1ericheath wrote:Looks as though the brackets could be rotated around 160-170 degrees to the inside for a tighter pull back.
Looked goofy with them turned in, so tried them rotated outwards. I also ditched the two lower brackets which allowed me to drop the headlight about 2"
The left bank (cyl 2/4) was having a constant misfire at idle and would correct itself at about 1/4 throttle. After setting and re-setting the timing belts (no covers), attempting to re-clean the carb, and adjusting the idle mixture screws; a carb overhaul was deemed needed. The old rubber seals after the second going through just couldn't hold up, so I bit the bullet and ordered EMSTD's carb overhaul kit and new timing belts.
EMSTD's kit came in the mail two days ago and being Sunday, I had some spare time to mess with the bike. Before I install the overhaul kit, I NEED TO BE SURE THE CARBS ARE COMPLETELY CLEAN. Does anyone have any tips for removing the pucks underneath the idle mixture holes in the air channel? I tried drilling into the puck and using a screw to pop it out but it is absolutely frozen in place. Will boiling in lemon water or using a chemtool carb bath clean this tight space? Each and every channel gets sprayed out with air after each method.
While I am at a standstill with the carb situation, I decided to run a dry compression test to verify the combustion chambers.
Cyl. 1: 150
Cyl. 2: 99
Cyl. 3: 149
Cyl. 4: 150
I pulled the left head off to find that the exhaust valves have made contact with the pistons. The pistons are in OK condition and do not have any holes in them. The valves do not look bent and appear to seat properly but I know judging by eyesight will not be enough to give me an answer. To determine if the issue is bad piston rings or a bent valve, I smeared a medium amount of 50w oil on the top side of the cylinder wall with a rag and temporarily re-mounted the head for a wet compression test. 104 psi. The oil gave me an extra 5 psi, so now I am %99 sure I am dealing with a bent valve. Any input is appreciated!
Over view
Cylinder 2
Cylinder 4
& a few other toys
& a few other toys
Pull apart and check straightness. Good time for new valve seals and lap. If they're not bent, you are lucky.
A large c-clamp works nice for removing valves. Cut a slot large enough for keepers. Good write-ups in Shoptalk on rebuild. Don't forget 2 new orings for the oil orifice per side. A good time to do the three cam seals as well, but can be done later.
I think the odds are a bent valve but it is possible to check since the head is off, if it will hold liquid. Fit should be tight enough that gasoline or equivalent (maybe water) will not leak out from the valves with the head laying upside down on the bench. Much has been said on here about using Honda head gaskets. I had several sets of off-brand from various gasket kits and used one on a recent build only to have to pull it back apart and replace with OEM.
- Hamp
I wish it was a bent valve because it would be less likely my piston rings are faultyericheath wrote:Pull apart and check straightness. Good time for new valve seals and lap. If they're not bent, you are lucky.
Intake and exhaust had a small leak on cyl #4. Both valves on cyl #2 (the bad cyl) held the liquid fine... Looks like its piston rings then..? A few months back, the engine was turning over very slow. I assumed it was a dead battery but it turned out cyl #2 was hydrolocked (for about a week). Is it possible the fuel ate away the piston rings? There is a slight brown stain on the bottom of #2 cyl wall.Easter wrote:I think the odds are a bent valve but it is possible to check since the head is off, if it will hold liquid. Fit should be tight enough that gasoline or equivalent (maybe water) will not leak out from the valves with the head laying upside down on the bench.
& a few other toys
& a few other toys
Never heard of fuel eating rings
Has the bike been sitting for an extended period (years)? Might just be stuck rings. I would be inclined to clean up the heads (even lap the valves and double check for a bent valve) and put it back together. Run it for a while and recheck the compression. Worst case you will have a good set of heads for your next short-block or engine.
- 92 Replies
- 14756 Views
Last post by J Wright
- 12 Replies
- 416 Views
Last post by bladredhead
- 1 Replies
- 416 Views
Last post by Schick
- 6 Replies
- 335 Views
Last post by large daddy rabbit
- 3 Replies
- 267 Views
Last post by 5speed
