My First Goldwing Build
- duke182
Re: My First Goldwing Build
Here in Arkansas you dont have to have marker lights or blinkers.
So I took them off of my 84. My road king has the rear lights but not the front.
I use hand signals.
Kinda dicey though, seems like fewer and fewer folks understand hand signals.
I guess the danger adds to the fun.
Check the regs then do what you're comfortable with.
Might be a real adventure in the big city.
Btw, the mini bike rocks.
Tell your son he did a great job designing his bike.
And tell the teachers to.....
Im sure you know what to tell the teachers.
I use hand signals.
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
I will be using turn signals. Just dont know if I like the idea of 3 "headlights" on the front. Kinda leaning towards the less is more idea.
84 GL1200 currently under transformation
Custom 212cc chopper built for my son
"The more I cut mine up, the more yours is worth"
Thanks for the compliment on his bike. He loves it. It was his last day of elementary school so he asked me to bring it up. Then he came out of class and his teacher's jaw dropped and she said,"oh, I guess you do have a motorcycle, you don't really ride it do you?"
His response, "I do, wanna see?"
Then he hopped on it and rode down the sidewalk and right on down the street to where my friend lives. He must have had 20-30 people cheering him on. We waited about a half hour for traffic to die down and both rode home. He didn't stop smiling for at least a week.
- duke182
Great story.
1984 1200 standard
vote in my poll
1984 1200 standard
vote in my poll
So, today I was making up the bracket for the right side of the "tank". I decided to start it up and check the clutch for some reason. Had it on the mid stand. Started right up, clutch in put in gear and the wheel started turning. I hit the brake and the engine died. So, the clutch is not disengaging. I noticed some fluid coming from the rod on the lever. Can I rebuid the master? Or is it a better option to look for another master?
1320bd wrote:So, today I was making up the bracket for the right side of the "tank". I decided to start it up and check the clutch for some reason. Had it on the mid stand. Started right up, clutch in put in gear and the wheel started turning. I hit the brake and the engine died. So, the clutch is not disengaging. I noticed some fluid coming from the rod on the lever. Can I rebuid the master? Or is it a better option to look for another master?
Yes you can get rebuild kits for the master. I think you can rebuild the slave cylinder too.
Does anyone know if the master is my problem? When i bled the clutch i got pressure out of the bleeder for about half the pull of the lever. It feels good but it obviously isn't releasing the clutch, any ideas?
Most have to turn the bars to the left, tie the lever in the pulled position and leave it overnight. You want gravity to slowly bleed everything. As long as everything is slightly uphill from slave to master, the air should come up. You could even loosen the lever from the bars and prop or tie it so it's all uphill. That's what I have had to do and it works.
ericheath wrote:Most have to turn the bars to the left, tie the lever in the pulled position and leave it overnight. You want gravity to slowly bleed everything. As long as everything is slightly uphill from slave to master, the air should come up. You could even loosen the lever from the bars and prop or tie it so it's all uphill. That's what I have had to do and it works.
He's working on the clutch master. So he would turn the bars to the right for that one.
Thanks, Robin. Brain not fully engaged again. Must hair in my lines.
So now that the holidays are over I started back on the project. Figured out my clutch problem with a ton of help from you guys. Turns out that the clutch was stuck. Just ordered speedo and tach, new grips and mirror mounts. Think I finally decided how I want the "tank" to look and plan to start glassing that next week. Also, my son has decided that it is time to finish his fender on his bike so that will probably be done before mine, but then I can make him work on my bike. To all those that helped my with the clutch problem, thanks again
I've bled several of these clutches, no need to do anything special. Just bleed them until the fluid runs clear and close the valve up. If the clutc his not kicking out it could be either the master or slave. The slave is a piece of cake to rebuild, and rebuild kits run about 15 bucks on ebay. I use KL kits with no problems. Part number cck-102 clu slave rep kit H 32-0146
- Norbert R
Cool chopper and cool story
I'm keen to see how you glass in the shelter, need to do something similar so keen to learn how you go about it
So, I was checking Craigslist for a tank for my son's bike and someone has a tank cover for an 81 GL1100. My question is, will it fit on my 84 1200? It would save me the time of having to modify mine. I still will probably modify it, but the 1100 one is only 25.00
Also, looking for the lockring for the fuel tank, which he has also. So will anything fit or not fit from one to the other? Thanks again guys. Even if the cover will fit, I will still modify mine, might be cool to have 2 different looks to go with.
- gearhead4207
- My Album: http://s1366.photobucket.com/user/gearh ... %20Uploads
Hey congrats on the wing and welcome from cali and the boys bike looks awsome and bet he loves it i got my first bike about fith grade .I think i turned out all right just cant stop riding them .lol. on the 1200 the 1100 tank shelter will fit with minor mods it doesnt quite match the side covers but is alot cheaper than the 1200 standard tank shelter .For 25 i would do it and it doesnt have to be mod as much .hope this helps . ps did your bike have the stereo and all the goodies if so ive got an 87 that needs fairing parts if you still got it at tax time i would be interested in the whole fairing minus windsheild .
83 gl 1100 i stripped gone but not forgotton!
82gl1100sold black betty
81 gl1100sold
78 gl1000 bagger mongrel sold miss you my friend
87 aspencade sold
84 aspencade f4-b build :mrgreen:back
87aspy stripping for road warrior
81 gl1100sold
87 aspencade sold
- 12 Replies
- 640 Views
Last post by rcmatt007
- 17 Replies
- 1054 Views
Last post by duke182
- 34 Replies
- 2806 Views
Last post by Track T 2411
