1980 GL1100 cafe
- ogrebro
1980 GL1100 cafe
Decided I needed a new project so bought a 1980 GL1100 standard to build a Cafe bike. One of the things I would like to do is put later model front forks, brakes etc on this. I was looking at my sons FZ1 Yamaha this morning and it looks stout enough. I've seen some pics of other front suspensions on wings but have no idea of what was used. What doner bikes work and how hard are they to adapt? This is my 4th wing and I'm looking to build a comfortable cafe!
Thanks!
Bill
Thanks!
Bill
1980 Interstate, 2be Café
- irishcarbomb
Re: 1980 GL100 cafe
First gen Hayabusa front ends have been used, I went with 03-04 gsxr 1000 (by accident). Without spacers it lowers the front 2". Its quite an easy swap, just requires grinding down the frame neck a bit and a bearing conversion kit from All Balls Racing.
Welcome to NGW! Lots of knowledge here... You can see pictures of how they look on my bike in the build thread(linked below in my signature)
Mine became a bit of a combination with gsxr 1000 forks/wheel, 750 brake calipers and hayabusa discs.
- ogrebro
Re: 1980 GL100 cafe
Thanks! Guess I need to do some research on stem lengths and check on rear ended GSXRs.
Thank you again!
Bill
Thank you again!
Bill
- Old Fogey
Re: 1980 GL100 cafe
That would be a bit of overkill on a GL100, dontcha think !!irishcarbomb wrote:First gen Hayabusa front ends have been used, I went with 03-04 gsxr 1000 (by accident). Without spacers it lowers the front 2". Its quite an easy swap, just requires grinding down the frame neck a bit and a bearing conversion kit from All Balls Racing.
(understand; no-wone on here ever mackes mistookes with spelling, nor enything else! ohno sir, not us )
Welcome to the nut-house. Ask away! Anything we don't know, we can sure make up an answer that seems like we do!
As far as I remember, early 90s CBR600 forks are a straight swap-in.
- ogrebro
Re: 1980 GL100 cafe
Old Fogey
As typing and computer usage are not my thing I beg forgiveness of the spelling gods!
I'm a old dinosaur when it comes to these things. I've been reading up on how to post pictures so I can show the beginning of this project and get some advice on the build I'm planning. Thanks for the input on the CBR 600 forks! Not having looked at them are they stout enough for an 1100 GW?
Thanks again
Bill
Thanks again
Bill
- Old Fogey
Re: 1980 GL1100 cafe
Bill, I am going from memory. My remembery is not nearly as good as my forgetery.
I think the 90s CBR's are 41mm diam. but I'm not sure on the length of them. Someone else on here fitted Magna forks to a Wing; pretty sure they are the same diam and probably a bit longer .
The Magna forks are too much longer for most builds. I think it was Dangeruss who posted the easier CBR swap. Here:http://ngwclub.com/forum/viewtopic.php?f=16&t=39516
I did the same with a Magna. Different look even with two inch longer stops?? to shorten it. It rides nice and sure firms up the feel. The V65 Magnas had 41 mm forks, same as CBR and gl1200. Cyborg did the full 1200 swap on his.
I think you will run into some wheel/ brake spacing issues.
- ogrebro
I'm wondering if there is a way to use a complete front suspension with steering stem, triple trees ,bars ,front wheel, brakes and all off of a newer bike to get a better handling GW. Is there any source that might have the specs of steering stem lengths to compare? This may sound foolish but this really intrigues me!
Thanks for the input!
Bill
Bill
- irishcarbomb
That is what I did...ogrebro wrote:I'm wondering if there is a way to use a complete front suspension with steering stem, triple trees ,bars ,front wheel, brakes and all off of a newer bike to get a better handling GW. Is there any source that might have the specs of steering stem lengths to compare? This may sound foolish but this really intrigues me!
Bill
Here are some good links I used when researching the swap. Hard to find info on stem lengths, but they provide almost everything else.
http://www.svrider.com/forum/showthread.php?t=135430
http://www.dotheton.com/forum/index.php?topic=5669.0
http://forums.kz650.info/index.php?topic=9105.0
- ogrebro
Thanks Irishcarbomb! This is going to make my head hurt really good!
Bill
Bill
- ogrebro
Well here is the beginning of this project in all it's glory
- 5-2-14-1.jpg (71.21 KiB) Viewed 1273 times
- Casper
I can see that bike is just screaming 'cafe me, cafe me!' Good luck with the build, start a new thread and keep us all in the loop.
Cheers,
Cheers,
- Barney T Weasel
Looking forward to watching this change...good luck!
GL1000 '75 model Blue....heading to rat, then cafe racer then full resto...owned 33 years.
http://www.dungbeetlebiker.com/forum/forum.php
Somewhere in the early part of this thread ( http://ngwclub.com/forum/viewtopic.php? ... tall+coils ) is a description of the adaptation of '93 CB1000 front end on a '75 GL 1000. It required some machining to the steering stem but was otherwise straightforward. I have about 600 miles on the bike and am very happy with the results.
Welcome and good luck.
Gary
Gary
- ogrebro
Well after a few hours work I've got her striped down. She looks pretty naked! I think I'll lose the Freightliner taillight and turn signals and look for something a little less obtrusive.
Bill
Bill
- 5-3-14-1.JPG (47.75 KiB) Viewed 1192 times
- 5-3-14-2.JPG (72.58 KiB) Viewed 1192 times
- 45 Replies
- 4726 Views
Last post by speedy69
- 7 Replies
- 764 Views
Last post by Steevensi
- 6 Replies
- 493 Views
Last post by rcmatt007
- 1 Replies
- 517 Views
Last post by Halfnaked
- 1 Replies
- 626 Views
Last post by desertrefugee
