Thought I would post this in case anyone could use these in a repair job.
The previous owner had snapped one of the plastic studs off that holds the left side panel on.
The first pic shows his repair solution...
The subsequent pics show how I fixed it.
I need to get or make a washer to go behind the latch. My hole saw was a bit bigger then the threaded part.
As well I need bigger washers for the stud. I left the rubber grommet in to act as an isolator to take the vibration out of the stud and latch and the supplied washers are a bit to small.
Other than that..it works great and was very easy to install.
shadow side panel repair...
- previous owners repair solution
- 20170217_141330.jpg (155.17 KiB) Viewed 147 times
- his failed repair
- 20170217_141453.jpg (165.04 KiB) Viewed 147 times
- stud removed.
- 20170217_142527.jpg (182.93 KiB) Viewed 147 times
- I need a washer added as my hole saw was a bit bigger than the threaded part.
- 20170217_143824.jpg (171.33 KiB) Viewed 147 times
- the stud.
- 20170217_143733.jpg (128.51 KiB) Viewed 147 times
Re: shadow side panel repair...
I'm going to put one on the other side panel to balance out the "look" and because they are a much more secure way to hold the panel on.
- the finished look
- 20170217_143805.jpg (176.25 KiB) Viewed 146 times
- 20170217_100819.jpg (139.53 KiB) Viewed 146 times
- Sugs
What's the diameter of the "button"? That looks like a good solution for the GL1000 side panels too.
_______________________
'79 Honda GL1000 Goldwing
The one I used is an inch. They make a smaller one and bigger ones. Also in different colours..Sugs wrote:What's the diameter of the "button"? That looks like a good solution for the GL1000 side panels too.
- scootsx2
Interesting fix. I like it.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- ascot
Where did you purchase these pins from?
Keep 'em running!!!
1976 GL1000 Yellow (daily rider)(sold)
1984 VT500FT Ascot (sold)
1977 Yamaha RD200 (barn find project)(sold)
1980 Honda XR80 (sold)
1972 Yamaha JT2 60 Mini Enduro
1969 Honda Z50A Mini Trail
right from quik latch.ascot wrote:Where did you purchase these pins from?
- Sugs
Oooohhh, they come in anodized black...
- 34 Replies
- 856 Views
Last post by salukispeed
- 4 Replies
- 696 Views
Last post by Gowing
- 12 Replies
- 468 Views
Last post by Kriss
