90 deg screwdriver wanted
- salukispeed
My son has a 93 CB750 nighthawk. While working on it last night it became obvious the idle mixture was set up very lean 2 5/8 turn out from factory. We spent over an hour taking the starter out to get clearance to remove the limiter caps for adjustment. When reassembled and set to 3 turns out it is incredible how much better it runs and idles. Now that it is assembled there is only 3/4 inch between the starter and the idle screw end and any fine tuning is near impossible on the #3 carb. I once saw a 90 deg screwdriver with a handle that allowed turning in such close quarters. Any suggestions??? Very tight.
Suggestions welcome.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
Re: 90 deg screwdriver wanted
Check with Motion Pro. I think that is where I got my good one.
- Graham Cracker
Might also find one where they sell boats or marine supply items.
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
- 05c50
Like Robin said, Motiopro sells a couple different ones. The more expensive one will get into tighter places and is much easier to use.
......Paul
......Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
- LuckyEddie
I have the Motion Pro one, works OK. I usually use a hex type screwdriver bit without the handle. Just grip it between my fingers and go for it.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
my local, non box hardware store has some. so if ya have one nearby, might check with them.
I have both a Craftsman™ and one of these fairly inexpensive on Amazon...
nice to have anywhere. I carry one in my GL tool tray.
H2G2=42
H2G2=42
This is the one I use for very tight places.
http://www.ebay.com/itm/Motion-Pro-Carb ... 5R&vxp=mtr
robin1731 wrote:This is the one I use for very tight places.
+1^^^^ I bought one of those last year and it works great.
Scott
- calif wingnut
- salukispeed
Funny, I just got back with that same Harbor freight tool. Thanks. I new it was too big but the small straight blade fits the screws great. There isn't enough room for even the bit by its self. I ordered two 3/4 inch MXL timing type pulleys and a 16 inch long x 1/8 wide matching belt that I will machine and then sandwich between .090 aluminum strips to make a belt driven 7 inch long driver that is only 1/2 inch thick including the bit end. This is stupid amount of work for a carb adjustment.
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
That sounds like a very clever solution!
Cliff (74yrs )
screw driver bits in a 1/4 socket on a 1/4 ratchet if you have room.
- salukispeed
I should post a picture. It was never meant to be adjusted once assembled. there is only 1/2-7/16 inch between the screw and the starter and oil lines plus they are shrouded behind a bracket, Kind of a set and forget mentality that is not friendly. thanks for the suggestions. I did complete the flat driver using pulleys but even it is too wide to fit. only 1/2 inch thick.
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
- 37 Replies
- 864 Views
Last post by alwing17
- 9 Replies
- 595 Views
Last post by Koboldwrangler
