Good idea Joe.... gets expensive - $250 for two of those things.
I sent Pazon and email - no elec. ignition for the GL 1000...
here is the reply:
Dear Bob,
Thank you for contacting us.
We do make replacement ignitor sets for some Honda models, including CB750F/900F/1100F/CBX1000 plus some CB650 and GL1100 models.
These ignitors are normally made by OKI and have the part number MPS-200.
There are two units on a four cylinder; one for 1-4 cylinders and one for 2-3.
They each have a small 6-way connector that plugs into the wiring loom.
Our units plug into the harness in the same way, but are a bit larger than the original.
If your bike has contact-breakers then these units will not be suitable, unless a set of electronic ignition pickups (and rotor) can be made to fit.
Many years ago we produced a Smart Fire (digital) ignition system for the GL1000.
When we were based in the UK, a small number were produced in conjunction with one of our dealers (Kirby Rowbotham).
He produced the necessary specialist hardware, and we provided the electronics.
Unfortunately this system is no longer available.
Best regards,
Andy Perkins
PAZON IGNITIONS LTD.
Keeping Classic Bikes on the Road
www.pazon.com PAZON IGNITIONS LTD.
274 Hot Springs Road
RD 2
KATIKATI 3178
Bay of Plenty
New Zealand
Tel: +64 75495878
Fax: +64 75495879
Email:
ignition@pazon.com
