Just when I thought I'd sorted it. Latest News
- jdvorchak
Re: Just when I thought I'd sorted it.
From what I can gather from the description of the starting problem. It is well known that when the starter needs to be removed, cleaned, install new brushes and make sure the brush plate "tabs" are clean and bent slightly. See the shop talk write up Roady did with pictures on how to do this.
Your starter is just old and tired and needs a good cleaning. Afterward it will spin as well as a new starter hot or cold.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- chewy999
It was new when I started my project, and the bike certainly hasn't done that many miles since I got it running. Saying that, those of you that followed my story will remember the time when it just wouldn't startjdvorchak wrote: Your starter is just old and tired and needs a good cleaning. Afterward it will spin as well as a new starter hot or cold.
http://ngwclub.com/forum/viewtopic.php?f=1&t=54238,
so maybe the starter took a hammering while I was trying to start her up. Will certainly check it out.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- chewy999
As suspected, bike started first time no problem this morning, guess I need to get the starter motor off and have a look inside. Despite being a new item, maybe I over did it when the engine wouldn't start before, and new items can be faulty!
The neutral light is on all the time now, will check the diode first as I put a new switch in this year, but not to good at chasing electrics, (not to good at a lot of things I hear you say).
Previous Rides,
Current bikes
Current bikes
- jdvorchak
More that one guy has ruined a perfectly good starter by cranking on an engine for 15 seconds, or more, at a time multiple times. If it doesn't start in 5 seconds there is a problem. If you just rebuilt the carbs and need to have the pump fill the float bowls, take an extra couple of minutes and remove the spark plugs before cranking and cranking on it.
2021 HD Triglide
John
2021 HD Triglide
John
I had a starter dragging from a bad bearing inside. It would on occasion try to start and then not. It happened to be the bearing that our local rebuilder had in stock.
- chewy999
Thanks for the replies so far, from what I know ( ) and what has been suggested I think it is a starter issue so will take it off and have a look inside, but not for a few days as got other stuff to do.
Previous Rides,
Current bikes
Current bikes
Remove the cable from the starter and check the nut that holds the battery cable stud on the starter. I had mine loosen up once. Check that all connections to the starter are good, including the bolts that mount it. Make sure that the ground wire from the battery to engine is clean and properly grounded to bare metal.
The brushes in the starter may be wearing down, dirty and sticky.
- chewy999
In the next few days I plan to get the starter off and have a look inside. Will post photos. Also plan to drop the engine enough to get at the (new) neutral switch and check that once and for all, before chasing the wires to see if there's a short, and test the diode in that circuit. Keeps me out of mischief!
Previous Rides,
Current bikes
Current bikes
- chewy999
Forgot to say. Been looking at the circuit diagram and I can see the neutral switch which is on the right hand side of the engine hidden by the frame. It also mentions a 'clutch switch' but I'm not sure what it means by that, what it looks like or where it is! Any ideas? (1980 GL1100)
Previous Rides,
Current bikes
Current bikes
I believe the clutch switch is located on the left hand clutch lever. Two wires plug into it, just like the right hand brake light switch.
- kerryb
I had the same symptoms, final fix after many other tries was to sand the corrosion/paint off the starter mount boss where it bolts to the engine block, clean the block too. No trouble since
- chewy999
That sounds promising, another thing to try. Many thanks,kerryb wrote:I had the same symptoms, final fix after many other tries was to sand the corrosion/paint off the starter mount boss where it bolts to the engine block, clean the block too. No trouble since
Previous Rides,
Current bikes
Current bikes
- chewy999
Found it! Never noticed it before so obviously didn't realise what it was!Track T 2411 wrote:I believe the clutch switch is located on the left hand clutch lever. Two wires plug into it, just like the right hand brake light switch.
Does anyone know if they are easy to replace if needed, new ones are still available,
Previous Rides,
Current bikes
Current bikes
The switch is easily replaced. There's another recent post regarding how to test it...
- 10 Replies
- 6898 Views
Last post by Whiskerfish
- 6 Replies
- 261 Views
Last post by Thunderdome74
- 31 Replies
- 2522 Views
Last post by robin1731
