I'm trying to finish a 1976 gl1000 basket case and ran into an over charging problem. Low voltage in the sense wire. In tracing down the problem I discovered a voltage drop in the ignition switch. I also discovered the switch supplied to me is a 6 pin and I should have a 5 pin. My question is can I install 5 pin repair kit in my housing that had the 6 pin originally ?
The 6 pin would work but the bike will run in any key position except "off". With the voltage drop iI know I'm needing a replacement but would rather go with the correct 5 pin kit if it will fit my housing. Anyone make this swap?
Looks like embo is the only repair kit available, from what I've read, seems a relay or two might help with the longivity of that make.
Ignition switch woes
1976 gl1000 sulfur yellow
1977 GL1000
1978 Gl1000
1998 Valkyrie Tourer
1977 GL1000
1978 Gl1000
Re: Ignition switch woes
Update, I stumbled across the "ignition switch cleaning" by peteybug in the how-to section so dissembled my switch, it was a mess. After cleaning the bike is charging at 14.6 v at 3000 rpm. ( it had been charging at 15.6 or so)Definitely poor contact in the switch was the problem. I can ride without worrying now, but I still would like to install the correct switch. Many thanks to NGW for all the info available here.
1977 GL1000
1978 Gl1000
1977 GL1000
1978 Gl1000
gradually getting my 76 finished. I still lack a headlight bucket and front turn signals but they are in the mail. A PO painted the side covers black but I found a spray can of Krylon that is close to matching, good enough for me anyway. I was also short a shelter lock but found a cabinet lock that was fairly easy to install. Put about a hundred miles on it in the last few days and am pleased. This was a basket case and it's been a learning experience that I've enjoyed.
1977 GL1000
1978 Gl1000
1977 GL1000
1978 Gl1000
Progress!
- tirejoe
D00D! that is awesome. serious congrats!williwm wrote:
...This was a basket case and it's been a learning experience that I've enjoyed.
H2G2=42
H2G2=42
- 13 Replies
- 1397 Views
Last post by Mojogameplay
- 381 Views
Last post by brianinpa
- 12 Replies
- 1240 Views
Last post by jdvorchak
- 12 Replies
- 560 Views
Last post by Irishman1
