Wheel weights on rim
Just curious...took my wheels to shop and got new tires put on......how much weight did they put on your wheels to balance out
- flyin900
Re: Wheel weights on rim
There is no correct answer here as every tire and rim will be different in some form. I have had wheels and tires that needed no weights and some that looked like they had a gym's worth of weights attached.
Another option if you have lots of weights and don't like the look is the Dyna beads or an equivalent manufacturer. These are small beads that get introduced into the tire once mounted through the air valve and get great reviews on performance in replacing weights on the rim.
Current Bikes:
Yep the new shinko 230's and rims look like they have a dumbbell rack full of weights on them...... they have fresh tubes also...... place I took them too said I couldn't use the beads with tubes..... did he know what he was talking about????? I wonder.....
I have used the DynaBeads with tubes. It can be a pain installing them, though...
Rockdog wrote:Yep the new shinko 230's and rims look like they have a dumbbell rack full of weights on them...... they have fresh tubes also...... place I took them too said I couldn't use the beads with tubes..... did he know what he was talking about????? I wonder.....
If they were off that much they should have broken the tire down and rotated it on the rim. Sometimes you end up turning them 90 degrees or more if they are way off. Much better than putting a lot of weight on it which could come off.
- mopehead440
Beads in tubes are absolutely no problem! Have run them for years! If you have straight stems, I would recommend the valves with stainless steel screens in the core. They are available from your bead distributor! For a buck, it's great to be safe!
1975 GL1000 Red
1975 GL1000 Blue/Green
1976 GL1000 LTD
1976 GL1000 Sulphur Yellow
1997 Valkyrie Custom
1999 Valkyrie Interstate Trike
2001 Valkyrie IS
2012 GL1800
2014 Indian Vintage Chief
2015 Indian Scout
2016 Indian Jack Daniels Limited Springfield
1976 GL1000 LTD
2001 Valkyrie IS
2012 GL1800
2015 Indian Scout
You can use beads with tubes. There is a pneumatic tool that will shoot the beads in. There is one at the place I work, I use it to get beads in wheels that are mounted and inflated. It was actually made to be used with equal balancing powder, but it will do the beads if you get the hang of it.
As for using the beads with tubes...I've had better luck balancing a tube type wheel assembly with beads than an application that doesn't use a tube.
One other thing, that really does make a difference on any tire other than a Goodyear...Make sure the red dot on the tire is lined up with the valve stem. Some wheels will have a simple or sticker to indicate where the dot should line up. It's call mount matching.
But usually on bikes, it goes with the valve stem. And Goodyear doesn't make bike tires, so that's not going to be an issue I guess.
1976 gl1000
- 14 Replies
- 456 Views
Last post by kenai
- 36 Replies
- 1163 Views
Last post by Placerville
- 7 Replies
- 225 Views
Last post by scootsx2
- 11 Replies
- 728 Views
Last post by Old Fogey
