Went to install the wiring harness in my 75 GL1000 today andddddd of course the frame now blocks the neutral safety switch...
Best way to sneak a screwdriver in there to reattach? Or will I be pulling the motor ... again?
That Stupid Neutral Switch
- BigBrian27
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
Re: That Damn Neutral Switch
The book says spread the frame little.......And I have used an angled screwdriver
- BigBrian27
I will give that a shot!CYBORG wrote:The book says spread the frame little.......And I have used an angled screwdriver
On a separate note, any diagrams showing the wiring harness routing?
same book......honda service manual. Has a picture
I did the same last week. Luckily the screw wasn't tight and I managed to get by the frame at an extreme angle with a long screwdriver and got the screw out. Got the wire on and used a small pair of pliers to tighten. Wasn't too difficult in my case.
Edit.. I may have used a #1 phillips, it would just grab enough to turn the screw.
1976 gl1000 sulfur yellow
1977 GL1000
1978 Gl1000
1998 Valkyrie Tourer
1977 GL1000
1978 Gl1000
- BigBrian27
Got it! Thanks all!
- Dirty Dave
Re: That Stupid Neutral Switch
I used a wooden wedge to spread the frame and replaced the Philips head screws for the oil screen plate with hex bolts (or Allen head). Makes access to the stupid neutral switch easier.
1978/9 GL1000
1997 Honda Valkyrie
2018 Kawasaki Z900 RS
1997 Honda Valkyrie
