You've confirmed you have probably one float valve sticking open. That was done when you turned the petcock off and it started running better. You could probably fix it with just a cleaning. No need for a new one. Many times doing what you did will remove the offending piece of crud that is causing the issue. Empty float bowl, then sudden rush of gas, washes the crud away.
If it runs good otherwise I'm not even sure I'd put new kits in it. Other than you would already have the rack off. And the rubber is all 39 years old.
hitting on three
Re: hitting on three
Kind of reminds me of someone's rear tire a few years back.robin1731 wrote: And the rubber is all 39 years old.
that might also help in seeing if was floodedericheath wrote:Might not hurt to confirm the plug is not fouled. Swap and see if it goes??
- jdvorchak
Try tapping on the float bowl with a screwdriver handle to shake it loose.
Check for wet fouled plug. My 1200 used to let a little fuel by the float on #2 if I let it sit for a few weeks. I'd start it up and hear that it was running on 3 then after a minute it would clear. Sometimes it didn't so I'd pull the plug and dry it off with compressed air. Other than that it never showed any signs of flooding and it was so intermittent I didn't mess with it.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
After only 39 years? You think Honda could have done better!!!
