eBay master cylinder rebuild kits
propav8r
Post by propav8r »
Has anyone used the ubiquitous eBay master cylinder rebuild kits? Is the fit and quality decent, or should I be looking elsewhere?
flyin900
Re: eBay master cylinder rebuild kits
Post by flyin900 »
Not sure what brand of kit you are referencing here. I have used the K&L aftermarket rebuild kits a number of times on various different bikes and had no problem with the quality. I believe they are a Japanese branded manufacturer.
Current Bikes:
if they are from georgefix, they are great
sunnbobb wrote:if they are from georgefix, they are great
^^^^^^^^^^^^^^^^yep
He sells the K & L kits.
propav8r
Post by propav8r »
Good to know. I sometimes forget that "eBay" isn't a brand...I just subconsciously lump everything on ebay under the same quality level.
jdvorchak
Post by jdvorchak »
I quit rebuilding brake MC when I found this guy on eBay. I get a new MC, brake lever and pivot bolt, hardware, banjo bolt, crush washers and usually a spare rebuild kit for less than $30. Have bought at least 3 of them, for various bikes, and could not be happier. They are not for the purist look for OEM but if you want an MC that works without rebuilding? I highly recommend them.
http://www.ebay.com/usr/megactore?_trks ... 2749.l2754
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
propav8r
Post by propav8r »
jdvorchak wrote:I quit rebuilding brake MC when I found this guy on eBay. I get a new MC, brake lever and pivot bolt, hardware, banjo bolt, crush washers and usually a spare rebuild kit for less than $30. Have bought at least 3 of them, for various bikes, and could not be happier. They are not for the purist look for OEM but if you want an MC that works without rebuilding? I highly recommend them.
Something like this? http://www.ebay.com/itm/16mm-Honda-Brak ... SwZ1lWgk6J
jdvorchak
Post by jdvorchak »
Yes sir that is the exact seller. Price is always around $30 and note that one comes with a spare "Piston kit". The only thing to watch for is the output of the brake line. Does it look like your existing brake line will work? Some of the MC have the banjo bolt fitting coming out the front and some out the side.
Oh I forgot in the previous post they also come with a new brake light switch installed if the OEM one had it on the MC.
Also, and I've never seen that before, that one looks like it comes with the clutch lever/perch as well! You'd spend almost that much on the two levers alone!
2021 HD Triglide
John
propav8r
Post by propav8r »
jdvorchak wrote:Yes sir that is the exact seller. Price is always around $30 and note that one comes with a spare "Piston kit". The only thing to watch for is the output of the brake line. Does it look like your existing brake line will work? Some of the MC have the banjo bolt fitting coming out the front and some out the side.
Yes, looks like the outlet is roughly in the same spot. I did have to purchase a replacement clutch lever since mine was all worn out and cracked. I'll go ahead and buy this clutch/master combo and see if the cable fits. It should. If not, I'll just roll with the OE on one side and the new master on the other.
tlbranth
Post by tlbranth »
My clutch lever has the switches integral with the perch. If you buy the after market clutch lever, you'll need separate switches. I've seen them advertised but not sure I'd trust Chinese switches.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
propav8r
Post by propav8r »
I wound up purchasing the master and clutch setup linked above. They both work perfectly. The clutch perch has an integrated switch which seems to work just fine.
tlbranth
Post by tlbranth »
propav8r wrote:I wound up purchasing the master and clutch setup linked above. They both work perfectly. The clutch perch has an integrated switch which seems to work just fine.
Which link Propa? The specs mention nothing about clutch-side switches on the one I looked at
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
jdvorchak
Post by jdvorchak »
2021 HD Triglide
John
tlbranth
Post by tlbranth »
Yep. I see it but there's no mention of clutch side switches.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
propav8r
Post by propav8r »
tlbranth wrote:Yep. I see it but there's no mention of clutch side switches.
I'm telling you, I bought it, it's there, and it works. There's even a little set screw on the bottom so you can slide the switch in and out and set it so that it opens and closes wherever you want.
