voltage rectifier replacement to a more modern one
- Lead Member
Just bought a new voltage/ regulator off the net. not orig. to the 79 wing, but I'm trying to keep up with something more reliable than 30 year old electrics. As in my last post with the main fuse melting. they say plug and play , [connector and wire colors seem to be the same , cbr600-1000 part.] what should I be worried about? You know there's Always something. Mr murphy always shows up. Plus the wife always says what did u do know! Any special things I should know about. I hate to see smoke. [sometimes]
- Toehead
Re: voltage rectifier replacement to a more modern one
Many (including myself) have done that conversion. Wire colors match up (IIRC). It doesn't matter which order you connect the 3 yellow wires. Just make sure all you connections are clean, etc and remove the stock regulator from under the false tank. Now's a very good time to check the condition of your stator plug. They have a habit of melting.
Some even bypass it: http://ngwclub.com/forum/viewtopic.php?t=32968
With this new rectifier, you'll get the benefit of some additional charging system capacity and an internal voltage reference. It's a nice upgrade.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
Plug and play, eh?
Perhaps, it's an Oregon Motorcycle Parts rectifier/regulator assembly?
A photo of the unit, or a link to the vendor website, please?
Cliff (74yrs )
- AussieGold
here is the one i used.
http://www.ebay.com.au/itm/HONDA-CBR600 ... 3abc0f11f6
had to change the plug, but thats no biggie. got them on three bikes. all work very very well.
there is no need to add any sense wire, not needed. they are regulated internally. here is some info.
http://www.wingovations.com/regulator-r ... 4579471117
with many thanks to Old Fogey for making this info freely available. and here is the why and how of the things.
http://www.superhawkforum.com/forums/kn ... how-25117/
which explains quite clearly how a Mosfet r/r works. doing away with the sense wire, prevents a lot of hassle.
the thing to look for when buying one is the " FH " on the casing, meaning mosfet type and not " SH " which signifies a shunt type.
in my opinion this is a must do upgrade for any older bike.
Mentor to all self appointed (and genuine) GURUS.
An LTD is........it just is.
- 37 Replies
- 845 Views
Last post by maury
- 18 Replies
- 661 Views
Last post by FADM Stern GNSF
- 17 Replies
- 928 Views
Last post by Gowing
- 12 Replies
- 503 Views
Last post by heraldhamster
