Length of the vacuumpiston-springs!
sunyammer1111
Brass Member
Brass Member
Post by sunyammer1111 »
Hello together!
I must know the unloaded length of the springs in the vacuumpistons for the Keihin 755A.
Thank you very much! anim-cheers1
Cheers Jan
Placerville
Re: Length of the vacuumpiston-springs!
Post by Placerville »
Courtesy of Alwing17
Placerville - 1976 Yellow
Survivor - BOTM - May 2011
New and Confused ?
Push the Big Button
sunyammer1111
Brass Member
Brass Member
Thank you very much, Placerville. Thats awesome!!! :)
Placerville
You're welcome but, I just stole the image from another thread I remembered seeing. Image by Alwing17 posted by Whiskerfish.
New and Confused ?
Push the Big Button
sunyammer1111
Brass Member
Brass Member
Are you sure Placerville?
In my '75 there are 51mm springs mounted. By constant driving the engine stutters. Is that the reason for the unsettled running?
sunyammer1111 wrote:Are you sure Placerville?
First thing to check is to make sure you have '75 carbs.
sunyammer1111
Brass Member
Brass Member
Hey Robin!
The carbs are 755A!
I have 4 sets of 77 carbs. Two sets had the longer springs 67mm and two sets had the shorter springs, 51mm. The shorter springs ran rich and bogged a bit when giving a lot of throttle. The 75 carbs had an even larger main jet than 76 and 77, so I would guess that the vacuum overcomes the spring and lifts too early with the shorter springs. The economy with the shorter spring versions in mine was 37mpg almost any way I rode it. The longer springs could get in the 40's. I would look for the right ones. Octane has a suggestion on how to measure the springiness. I remember a few years back people talking about stretching them back out to shape, but the feeling was that you'd be pretty inaccurate.
pistolpete
Post by pistolpete »
Guys,
After hundreds of sets and some research, the standard 75 - 77 are 51mm (2.007") with 19 winds, .027" dia wire.
The standard 78/79 are 67mm (2.64") with 11 winds, .023" dia wire.
Pete
Pistol
Placerville
...and the plot thickens.
New and Confused ?
Push the Big Button
fish
Post by fish »
[quote="sunyammer1111" By constant driving the engine stutters.?[/quote]
allways start any repairs with the ignition system.
Check your point gap & timing
Timothy Mark Fisher
Catalina Arizona
The plot hardens. Wow, Pete, you would know. Alwing is pretty reputable too. Mine had the same number of winds, just considerably different lengths. Who's taking side bets? I have pic here somewhere of mine. Here:http://ngwclub.com/forum/viewtopic.php? ... b736fd5389
pistolpete
I know that we receive carbs that the spring length is all over the map. If it has 19 winds and it is longer than 51mm, someone has elongated them. I have a new carburetor for a 77 and the spring length is 51mm with 19 winds. As someone has stated before (I think it was Randakk), the length of the spring doesn't mean much as far as functionality is concerned.
I may be in error about who said it though.
Pete
Pistol
pistolpete wrote:I know that we receive carbs that the spring length is all over the map. If it has 19 winds and it is longer than 51mm, someone has elongated them. I have a new carburetor for a 77 and the spring length is 51mm with 19 winds. As someone has stated before (I think it was Randakk), the length of the spring doesn't mean much as far as functionality is concerned.
Pete
I won't take credit for it but I have said it. Just like valve springs what matters is spring pressure at a given height.
