Valve lapping
Valve lapping
I did a valve lap, my first, on a set of 1000 heads. Thanks to all the tutorial helpers here again. It seemed pretty straight forward. Question to the experts: I have what look like stains in the valve seats. They appear to be smooth as a baby's bum, but they have what look like small stains across the area of the seat that the valve sits on. Is smooth good enough or should I keep grinding until they have a uniform color? It appears it will take a while to remove them. It looks like there is plenty of seat left to grind, just a slow process. Any advice appreciated in advance. I'll be doing the spindle swap per Old Fogey tonight, I hope. I forgot to get cam seals, but I think they can be installed anytime.
joedrum
Re: Valve lapping
Post by joedrum »
id say stop
1979 1000
Greg
Re: Valve lapping
Post by Greg »
Stop when you can pour alcohol and not have it leak in to the head chamber. I don't know what the discoloration you speak of might be, but if the valves can keep back alcohol then you are pretty much assured the job is well done. IMO.
Oldewing
Secretary
Secretary
Re: Valve lapping
Post by Oldewing »
Your fine, a little stain is just that.
Nice job, new seals I trust.
Re: Valve lapping
As stated, it's pretty normal. Use the alchohol method. That's what I do. You'll be there forever trying to get those out just lapping them.
Re: Valve lapping
Good, thanks for the replies. They seem like they seal pretty well.I'll try some alcohol tonight.
Re: Valve lapping
ericheath wrote:Good, thanks for the replies. They seem like they seal pretty well.I'll try some alcohol tonight.
No need to let it soak. Just pour it in enough to be sure it covers the head of the valve. You'll know within a few seconds if it is sealed. If it seals good then pur it back in to the same container. Then go on to the next one. I use a cheap plastic cup that way it "bends" easy and I can pur it in without spilling any.
Re: Valve lapping
lolol I thought you drank it when done? shakehands
Re: Valve lapping
ericheath wrote:lolol I thought you drank it when done? shakehands
It's rubbing alcohol. If you drink that even before pouring it in there is a problem there. lolol
